R80 emulator sound problem
I've used the R80 Emulator on my old pc without a problem - but since installing it on my laptop I get a crackling background noise (everything else works fine). I've tried messing about with the ini file with no luck. Can anyone help, or should I just go for another emulator?
Post edited by Rockford on
(Otherwise programmers will feel that work for nothing :) )
(ctrl+f "Sound Card").
If nothing happens, then reinstall your sound card drivers :), or use other emulator.
Then, that's your problem. R80 is a MSDOS application. It won't sound right until you download and install VDMSound (it's free), which provides a better emulation of the soundsystem in MSDOS than the Window's NTVDM does.
Note that it's not necessary to completely disable accelleration, but moving the slide to the left just one position at the time until the problem is solved.
I use ZXSpin now as it seems to do just about everything.
