Portable mp3 players
edited November 2005 in Chit chat
I was looking at the CREAM CMP3-01 512MB mp3 player at Comet, and looking at the tech specs it says on the Comet website that it requires 20GB of storage space on your PC to run the software that comes with it. Surely this is a mistake? 20GB?? I don't have 20GB spare on my computer for sure. Is this common for mp3 players?
Post edited by Spector on
  • edited November 2005
    thats prolly to store temp files of the mp3s? or for storage for converting them?
    Sounds like a mistake especially because it's only a half a gig player.
    Skarpo
    Sod the software that comes with it. if you're running XP, I can guarantee that you won't need the software, as XP will assign it as removable storage, and all the space you'll need is the space for your MP3's/WMA's.
    Starglider is right, there's no need for the software at all if you've got XP (and possibly 2000).
    The only reason you'd need to install any software is so you could reflash the bios on the player. Something I doubt you'll ever need to do.
    It'll appear as a removable drive next to the CD/DVD drives in My Computer. Just copy your mp3 files into it and away you go.
    _________________
    Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
    "I'm not biased - I don't care who beats the English" - Gunnar
    [ This Message was edited by: VincentAC on 2005-11-27 20:09 ]
