Can't use the joystick
edited March 2006 in Emulators
I can't play with my the usb joystick with Emuzwin. With other emulators i don`t have a problems. Everypeople Can I help me? Please
[ This Message was edited by: pionero on 2006-03-05 12:09 ]
Post edited by Pionero on
  • edited March 2006
    You may be did not turn it on in the Control menu? Did you see also Configuration (Joy&Mice). (Joystick should be installed in the system, yes).
  • edited March 2006
    At first, Thank you for your quick response, I turn it on in the control menu and I have the joystick installed in the system. In the others programs I can chose the PC joystick and see my USB JOYSTICK, I chose it and I can play with him.
    For me, Emuzwin is the better, but I don't play with my joystick. Can I try another thing?
  • edited March 2006
    I said about Configuration. It seems it can be turned off there (or may be assigned to another device). I use Direct-X joystick interface in API, so if it is there and did not captured by any other program it should work.
  • edited March 2006
    It's possible I have another problem in my pc.
    On configuration I can't see the devices and I select: Single Joystick, Joystick on at start of emulator.
    I can see my device on configuration of joystick in XP when i connect my usb joystick.
    Nevertheless,thank you for your help.
  • edited March 2006
    If you do not attach joystick for all time, it is better in the Configuration to check off "Joystick at start of emulator" and to check it "on" in the menu or in the Configuration when it is already attached and system is seeing it.
  • edited March 2006
    i'm sorry to say i'm also having big problems with USB joysticks and emuzwin. :(
    I have a usb interface that allows me to plug in two playstation pads, to act as normal joypads. They work great on such things as Spin and winUAE, but on either "single joystick" or "both joysticks" mode, the input is all screwy.
    I've been using Manic Miner as a test, and for some reason first, he'll keep jumping, when the "joy on" config is off, despite my default settings i am trying to use. Then, when this stops and the joystick is on (either mode) he'll constantly be walking left, but no longer jumping... although the joystick inputs themselves are working. (i can jump move right etc)
    I am having to unplug the joypads and reload just to play games on keys at the moment, since it seems very odd and randomly selected the way the inputs are interfering, whichever change of settings i try.
    Any help would be greatly appriciated.
  • edited March 2006
    For this question, answer is simple. Just some values for Threshold (e.g. 16) and press Set As Default button. (When add this setting I just forget to set some default value different then 0).
    I just connected Logitech WingMan to test it (USB) and works well. Certainly, I changed the threshold.
  • edited March 2006
    d'oh!!! yeah - worked out nicely.
    Thanks Vlad, i should have tried that!
  • edited March 2006
    I have 2 joysticks,with one a try yours intrutcions and it work OK with the other no, but NOW I CAN PLAY WITH MY USB JOYSTICK. Thanks for all Vladimir.
  • edited March 2006
    Unfortunately, I can not now test both joysticks attached. I know there were a problem earlier with 3 joysticks attached to a system but 2 worked when. May be you try to select another Spectrum interface to the second joystick or re-direct it to a Speccy keyboard (may be this just a reason). One tip: to see what is occur open keyboard pane (drawn keyboard) while experimenting. (It would be better to make special test area in Config, but I did not implement it).
