which pocket pc?
Hello I'm new to the forum, but my other half lives here!! I'm want to buy a pda, I've decided that a pocket pc is probably the way to go but which one?......I've looked at one or two sites and bought a magazine but there is quite a bit of conflicting advice. I would be grateful for any advice regarding makes/models and possible pitfuls/weaknesses etc from any of you who have used one. For once my other half can't help with this pc problem. Thanks in advance
Post edited by retro_widow on
I have an Asus MyPal 620 which is probably quite old now but it seems to be one of the best for retro gaming. I regularly play MAME, GBA, Speccy and many other games on mine with the 1 gig card i have for it plus the control pad is decent for gaming.
If you want it for retro gaming then i can recommend this, theres so many ones out there it just depends on what you want it for. If you want it for more of a basic fileofax then theres many cheap ones which can you do what you want, eg meetings/telephone numbers/solitaire for the train journey etc !
Ah, see, I'd go for a Symbian smartphone instead of Pocket PC. But each to their own...
Dunno. Maybe you'll get a cool sling bag to carry it in? Look wot the iPod did for the lanyard. :D
Size is the least of its problems, it's a full PC so it eats battery life, especially if you're trying to run something like Halo. And it would cost a fortune to make too.
I now have a charger in three rooms of my house and carry the 770 around with me.
The Nokia 770 isn't a PC though, it was designed for mobile use only and runs a special version of Linux.
The "Origami" is a full Windows XP PC (it's XP tablet edition which is the same thing really), and is effectively a laptop with no keyboard.
Using it while recharging... why not just use a laptop?
I'm posting here on it now, and I'm flat out in bed with the lights out, listening to MP3s streamed from one of my "real" computers.
No, I won't tell you what I'm wearing.
_________________
Nick Humphries
The Your Sinclair Rock'n'Roll Years: http://www.ysrnry.co.uk/
The YSRnRY Documentary (1986 SOON): http://www.ysrnry.co.uk/tvprog/
The Tipshop: http://www.the-tipshop.co.uk/
[ This Message was edited by: NickH on 2006-03-28 00:01 ]
Well if you want it for those reasons you just said most Pocket PC's will be able to do that. A lot of people seem to buy a Pocket PC and then all they do is keep phone numbers and calender entries. No point spending a fortune.
With a memory card you could then turn it into an ipod kinda thing as you can put 40 songs on it etc, if i'm working away i put some movies on it as well.
Excel/Word all work well, obviously get a foldaway keyboard for it as well as typing using the stylus is a bit of a pain.
For what you want it for i wouldnt spend a ton, if you get one about 400mhz it will be fast enough to run some decent games, watch good quality movies and be pretty fast.
also there is a version of Kings Bounty (old amiga turn-based rpg game) and its amazing.
