Tommygun Masking confusion.
See when masking a sprite in TommyGun, yeah, does red mean 'show the background' or 'don't show the background'?
I come from a SevenUp usage background, so I'm just trying to figure it out in TG.
Thanks
Thanks
Post edited by redballoon on
I think I originally wanted it to be the other way around, but a mask is really want is kept from the background and then merged with the sprite to make the new screen image.
So I ended up programming it that way.
Also the red area represents the 1's of the mask used in the assembly AND statement that does the masking.
Although, personally I find it easier to applied the masked red area over the actual sprite itself and not the blank areas around the sprite.
So maybe it should be selectable to have one way or the other?
What do you prefer?
Actually, now that I think about it....bugger.
Let me try it tonight and I'll let you know.
Cheers.
