playing the games on the real thing??!?
edited May 2006 in Games
hello, today i was searching for an old cassetes recorder at my place (doing some stuff related to audio/electronica) , didn´t find it but found my old zx48k ..
so is is possible to play this games we find here on this site in a real zx48k ..maybe with and audio cable connected between a laptop and the 48k and in the laptop making this files to run , like we do it on a cassete player? .. yes ? no?
other thing , i guess impossible, but let me be sure, .. if we can play it like that on a real speccy, there sno way to speed up the loading time like we do on an emulator, right?
thanks.
Post edited by untitled on
  • edited May 2006
    untitled wrote:
    hello, today i was searching for an old cassetes recorder at my place (doing some stuff related to audio/electronica) , didn?t find it but found my old zx48k ..
    Yes, you can indeed. Be sure to turn off any audio enhancements (but keep any high quality settings - Spectaculator lets you boost the volume iirc, and SPIN has reverb/wide stereo). Pipe it straight out - I've managed that on numerous occasions.
    thanks.
    Nope, unfortunately not. You can search the web for "UltraCarga" speccy games, which load a lot faster, but they can be very finicky with volume levels and such, and you'll only be able to play games that have been converted.
  • edited May 2006
    thanks! ..
  • edited May 2006
    If you're a serious speccy user (rather than a casual "thought I'd try out the old machine for a bit of fun" one), then you may like to consider one of the hardware addon's that allow you to load games from other devices such as a Hard Drive or Compact Flash.
    I can't comment on most of the devices as I've only tried out a handful, but as a guide a complete system to load from a CF card will set you back around ?40.
    Note tho' that most of the devices require a bit of work to build them, unless you can find someone to build it for you.
    'Tis just a thought.
