On 2003-02-28 09:26, Paul van der Laan wrote:
Hmmm. I sadly couldn't open the zip file with Stuffit Expander on OS X. Have other people experienced difficulties as well?
Sorry for the previous post, there was something wrong with my Expander. I managed to open the zip file fine today...
Wow! This must have been _a lot_ of typework! It looks really neat and complete.
I have a few remarks:
- I guess you used Distiller rather than the 'Virtual PDF writer': that's a good thing.
- It's Acrobat 4 compatible: that's also a good thing.
- You used TrueType fonts (Arial and Times) and that's not wrong, but not really recommended. PDF is PostScript and embedding TrueTypes can cause printing problems.
- What's the resolution of the pictures? Did you set the compression preferences to downscale them to 72 DPI? It might make the PDF's a bit smaller in filesize.
How can I prevent that? I created the original in M$ Word97 - and then ran the resulting .doc through the distiller. If I can remove any potential problems (and the times font, as I don't think I actually *used* it in the document), then I'd love to know how.
I think they're actually a bit small - I'd prefer a better, higher resolution myself :) I'll have a play and see what I can do.
Hey! What's going on here? All the text has uploaded oddly... I can't make that last bit out. Can you repeat that just one more time Dunny please? :D
There's little to be gained by zipping a PDF though, since the format uses compression techniques internally.
Works OK here (Linux/i386 or Solaris 9).
Right, going up on my site at:
http://homepage.ntlworld.com/paul.dunn4/EliteMan.pdf
so you should be able to see it.
Comments on it, anyone?
Thanks,
