probs with TZX
Hi,
just downloaded a game called Special Agent in TZX format. I'm using the Fuse emulator on a mac, and when I open the file it won't load the game properly.
Is there some special way to use TZX as I've had a lot of problems with it, I can generally only get TAP to work???
I really want to play this game as I remember enjoying it as a kid!!! Please help! :-?
Post edited by yogaboy on
Generally speaking TAP and TZX are treated the same, except that TZX is a more flexible format and is therefore more likely to contain fancy loaders that Fuse can't do its immediate-loading magic on. You want to go to Options -> General, turn off 'Use tape traps', start loading in the normal way (LOAD "" or choosing Tape Loader from the menu), then Media -> Tape -> Play.
This game requires you to type LOAD "" CODE
