Magnetic Moon?
Stuckstuckstuckstuck!!!!
I never had tryed Magnetic Moon before...And only had a 48k.
I'm playing the 128 port.
Anyone finished it, or can help me in the secound part?
I'm in level two found a bin in the locker room, a door that aparently doesn't let me pick it's lock unless an exactly right (picky, hum? :D ) phrase is used.
The help system in there doesn't help me much because I'm really tierd of writing things remotely related.
Thanks for the help! ;)
Post edited by ChicletK on
good luck :)
The only good one that coud help is a set of hints for all the three parts for the 48 port (some puzzles are diferent, room, help, etc) published in Sinclair User #126, but that exacly puzzle is diferent. :) Just my luck.
I really wanted to take it with me, but I not only didn't had space and the game warned something about "why do you want to take the wire? It served it's purpose.".
Put the location description where you are and what you are carrying.
Are you here? "You're near the west end of the long, carpeted corridor..."
Possetions:
Backpack
forcer
cutter
paper
glue
grapnel+rope
I'm just out the duck after using the paper to find the way to the room. I have access to all of level 2 exepting for the messhall and the door. I can also reach level 1.
Also, the axe is suposed to be eleminated when getting out of the ducks, right?
Just a thing, if you're helping me, can you just hint me?...It's more chalenging that way. ;)
Thanks a lot. ;)
Have you been here? Can you get here? If so, go there.
There's another cell around?....Or a charger? Most likely I've once again didn't noticed a basic location. :\
Sorry to bump, but it isn't necessary to start another thread, is it?
Thanks. ;)
Where the charger is?...In the ship? I get caught by Pocks if I try to go to the lower level, the engine room or the starboard lifeboat...And I can only find aparent junk in the storage compartment (apart from the flashlight).
EDIT: I've just had a look in the archive and there's a solution of sorts that helps with many problems in this game. That should help you when you're stuck?
I think I have to start to cut throught the plates in the ship to find it. Or kick the captain out of his confy chair. :)
No, it's much easier than that. It can be found on your fifth move from the start. Let's say you moved into the 'Ships Armoury'. Then you would 'Search Armoury'. Search everywhere!
If you're still stuck then let me know and I'll see if I can solve it for you.
