How can I transfer VHS to DVD, please?
edited April 2007 in Chit chat
I want to transfer my VHS cassettes to DVD. The videos are mainly of older films or TV series that aren't available on DVD, and are in PAL format (I'm in England). My PC is a 3.2 AMD, with Windows XP, and 512MB RAM, and I have a capture card somewhere, which I'm going to dig out later tonight.
What software do I need to do this, please? I have WinDVR somewhere, and that did this in real time, on my slower PC (a 1.8 AMD), but I want the best quality I can get (though of course I realise that the bottleneck here is the VHS casettes' quality, I won't get better quality than the quality of the recording on the video tapes themselves). Does WinDVR's realtime read-from-the-TV-card-and-write-the-.mgp-file method give the best possible quality, or would I be better off reading into an uncompressed .avi, and later on converting the .avi into a DVD compliant .mpg? Obviously the latter would be better if WinDVR's realtime mode produced substandard results, but does it?
And what software should I use to create DVD menus?
Finally, I don't have a domestic DVD recorder (that plugs into the TV, and acts just like a VHS recorder), or of course I could use that by just connecting the DVD-Recorder to the VHS and recording from VHS to DVD. What advantages/disadvantages are there to doing this rather than creating the DVD on a PC? For example, presumably when using a PC, I can set scene starts (where you go to when you skip forward a chapter), plus bulk record a full casette, then later on divide the file up into episodes (can I do this with WinDVR, or whatever software?). Can a domestic DVD recorder do this? What other differences between a DVD recorder and a PC doing the same job are there?
And is now a good time to buy a (PAL) DVD recorder, or are there still commercial arguments over which type of DVD to support (I don't want to buy a Betamax style DVD recorder that's obsolete in a few months time).
Thanks for any answers.
Post edited by ewgf on
  • edited April 2007
    pm sent...........
  • edited April 2007
    TV Card for the PC might be worthwhile. Connect VCR up, play (and record) through PC, then shrink and convert to DVD format...
    Just an idea...
  • edited April 2007
    You could try gently UHUing the tapes directly to a DVD and then hope your bestest that the DVD player of your choice will play it.
    Aside from that I am all in favour of TechnicianSi's suggestion. Never failed in our family before but you have to make sure that the card supports what you are doing, perhaps go with a combination of SVHS.
    Skarpo
  • edited April 2007
    Or buy a DVD Recorder and Scart the signal direct.
  • edited April 2007
    I've just bought one of these:
    http://www.amazon.co.uk/LG-16x-External-Writer-Inputs/dp/B000COJ08C
    for less than the price on Amazon I might add. It allows connection of external AV devices such as VHS.
    I'll let you know how it goes when it arrives.
  • edited April 2007
    u will have a problem with tapes that have macrovision protection though :(
  • edited April 2007
    dekh wrote: »
    thats what i do, a scart adapter plugged into mi dvd recorders input and then everything with an output gets plugged into that, can record anything to dvd
    if i want it as a computer file, i record to dvdrw rip onto the puter then wipe the disc and reuse :)
  • edited April 2007
    See, he's not just a manic miner. He'll nick anything...
  • edited April 2007
    Use TMPGEnc, it's the best available software for adding menus and editing mpg files.
  • edited April 2007
    Thanks for the answers, I'll let you know how I get on.
  • edited April 2007
    I use a Pinnacle Systems Studio DC10+ PCI card. It's a little old now, but it's been rock solid reliable for inputting video from an analogue source. It's not a TV card, but a budget end video editing card. If you can pick one of those up cheap somewhere, it will serve you well.
  • edited April 2007
    I use a nucleonic ferkinator myself.
  • edited April 2007
    MattLamb wrote: »
    How did you get on with this ?
    I also bought one of these, arrived today, went to install it and my normal cd drives/dvd re-writer have totally disappeared ?
    Anyone got any ideas how to get my drives back ?!
