Well, in this case hotswapping is where you go to the Disc Channel, insert a PAL Gamecube into your Wii, then you get you import Gamecube game disc ready. You click on eject then you click on the 'Start' button before it greys out and quickly remove the PAL disc and insert the NTSC disk. The Wii still thinks it's a PAL disk and loads up the game. Of course, some games don't work properly - sound but no images, for example.....that is if you get that far. Which I obviously can't. I suppose I could get my Japanese/US modded Gamecube down from the loft..but can't be bothered and there's no room next to my telly..just enough for my Wii.
It's shi$%y cold out here in Minnemasotadontchaknow ... Last week we had over 20degrees celsius ... now snowy and cold as heck!
Skarbrrr
