i caught a virus
no this isn't another sad tale of my social life, its a bonafide IT question.
so anyway my computer detected a virus. (i have Shopos) it was some malware. i couldn't clean it, as i don't have admin rights to. and id rather not tell the IT dept where i caught it from or at least them find out. so i found out where the thing had been downloaded to (temp internet file) so i deleted the folder it was living it, and sophos told me it wasn't there anymore.
will this have killed it?
Post edited by mile on
...and it is hard to give a more definite answer.
To be sure it is best to run a combination of anti virus/anti malware on it.
Without admin rights you may not be able to.
You could try Trend Housecall it's an online scanner. But it does need to install a kernal but there are two different technologies to try.
http://housecall.trendmicro.com/
You might get away with one or the other of the kernals. Have patience with the downloads/initialisations.
or mash up my PC so they buy me a new one.
yeah best get on the net :p
Strangly everybody I talk to says ignore this like the plague. Massive resouce hog apparently. Worse than Norton.
ADJB
It also blue screens your PC on a regular basis (which I verified by running under the Driver Verifier and the Kernel Debugger on a fresh install), I sent them a bug report and was told I "probably had a virus"
As to the virus, fess up and let your IT department know. The results of not doing so can be much, much worse....
not a chance. we're always getting infected. and if it hurts my machine i'd just get a new one. its 7 years old.
but mile probably only caught his current virus whilst treating the *wanks cock* virus...
No doubt if so the solution is hand cream....and a copy o' Club International :D
