Mebrane fix or LOAD"" Poke equivelant
edited May 2007 in Hardware
Hi!!
I bought a rubber speccy from a guy on Ebay.
Well,lots of buttons dont work,including J :(
Two questions...
*Is there a way to have a quick mebrane fix for this button?
*Is there a POKE that mimicks the LOAD"" command?
Thanx in advance
Post edited by Pyjamarama on
  • edited May 2007
    You could try MERGE"" then RUN, tho' there are a couple issues with that...
    The LINE of a program may not be the first line (hence RUN wouldn't work), and also the program may be protected (so MERGE"" wouldn't work).
    It should work in some cases, tho'.
  • edited May 2007
    RWAP will have you working again soon - he'll even fit it for you.
    Follow the RWAP link from my site - link in my sig.
    Oh bugger!<br>
  • edited May 2007
    Thanx guys for the responses!!
    I live in Greece so a RWAP solution it is a bit expensive for me right now(I have 6 speccys that play fine ;) ) but I will surely use it in the near future.
    I just want to test the machine to see if,apart from the obvious mebrane hell,there are other problems with it
    Merge is one of the keys that does not work either. agrrrr
    A Poke may save me :D
  • edited May 2007
    No, I don't think there's a poke that'll do the same as LOAD ""
    You could work out which lines on the membrane have to be switched to give you the right keyworks though, and that'll just be a few bits of wire - wouldn't reccomend it tho :)
    Actually, if you have lots of patience and a little luck, you could take the membrane out of the computer, find the break. If you're lucky and it's on the actual ribbon, you could try laying a very thin length of bare copper wire down the printed trace and the sticking it down with a length of sticky tape. If the break is "inside" the key area tho, then it's beyong repair IMO
    Oh bugger!<br>
  • zubzub
    edited May 2007
    icabod wrote: »
    Workaround: MERGE"" and then RUN a program that consists of just LOAD"". Of course, you'll need to save the LOAD"" program somehow, first, probably with an emulator.
    My sister and I did something similar to this ? we transferred LOAD"" to the Spectrum using the SAM Messenger, and then pressed ENTER on the Spectrum. :)
  • edited May 2007
    pitty that Merge button is also non-working :(
  • edited May 2007
    How about:
    10 PRINT ""
    POKE 23759,239
    RUN
    ...though if the key with MERGE on doesn't work, RUN might not either... in which case, GO TO 10 :-)
  • zubzub
    edited May 2007
    Pyjamarama wrote: »
    You could try entering 10 PRINT"" or 10 REM"" and then POKE 23759,239: RUN ? there are probably better ways to do this, but it seems to work. :)
  • zubzub
    edited May 2007
    zub wrote: »
    Oops. Seems yomlogs beat me to it! Sorry about that. :)
  • edited May 2007
    Sorry for the fuzz but the Speccy is collapsing...
    Now not even RUN works!!!
    DAMN!!!!
    Thanx a lot for your clever hints ;)
  • zubzub
    edited May 2007
    Pyjamarama wrote: »
    DAMN!!!!
    If both RUN and GO TO don't work, the next trick would be POKE <something>,247:NEW, or something along those lines. <something> would be the address where the "NEW" statement is held. I'm not sure exactly what that is, yet, though. :)
  • edited May 2007
    ahaaaaaaa!!!
    The help in WOS is neverending :D
    Thanx!
  • zubzub
    edited May 2007
    Pyjamarama wrote: »
    ahaaaaaaa!!!
    Thanx!
    Oops! :D
    Anyway, what I eventually came up with is:
    10 PRINT ""
    POKE 23759,239
    POKE 23787,247:PRINT
    The first POKE turns the first PRINT into a LOAD. The second POKE turns the second PRINT into a RUN. :)
  • edited May 2007
    zub awesome trick!
    it worked!!! (although I needed to plug in my Interface2 in order to input the numbers using the 2 ports and the joystick :D)
    thanx!!!
  • edited May 2007
    I was laughing enough at the extent of the POKEs needed just to load something, but then going on to say that the numbers had to be entered using two joysticks had me laughing my head off!
  • edited May 2007
    You could even do just:
    POKE 23779,239: PRINT ""
    (assuming a freshly-reset Speccy and no IF1)
  • zubzub
    edited May 2007
    zeem wrote: »
    Owww! My sides! :D
  • edited May 2007
    Have you tried opening up the Speccy and looked at the membrane? Is it a physical break or perhaps "old" liquid-remnants? Moisture can sit between the membrane(s) for a long time. I remember back in ... erm ... '88 I spilled a glass of milk (true story) over my little 48k ... I cleaned it up the best I could, dried hours on end (never opened it up though) ... for a few months the keyboard did work aside from a couple of keys I didn't use, something like "g" and "b" ... but then other keys started acting up. After a few weeks of the machine not working at all I was forced to opening it up and lo and behold there was still some moisture in the membrane. After a careful wipe-off I had my Speccy working again. Mind you that was after a few months (+ a few weeks) of the Great Milk-spill of '88.
    If you decide to open it up then be VERY, VERY careful when you take the membrane out of its connector on the board as it may be brittle by now. Avoid Bending The Membrane At All Cost.
    Good luck and all that jazz
    Skarpo
  • zubzub
    edited May 2007
    Pyjamarama wrote: »
    DAMN!!!!
    BTW, you could always use CONTINUE. (If that key works, anyway :))
  • edited May 2007
    yomlogs wrote: »
    Are you sure this works? It doesn't on my 128 in 48K mode! It's one thing to print on the screen the command you are trying to execute, but to actually execute it is quite another.
    ZUB's trick worked great tho - what a brilliant bit of trickery!
    Oh bugger!<br>
  • zubzub
    edited May 2007
    DEATH wrote: »
    yomlogs's even better trickery worked fine for me (in Fuse). :)
    Are you typing it without spaces? They would alter the required address.
  • edited May 2007
    DEATH wrote: »
    Works here too (in SPIN, 48k mode, all 128k models also in 48k mode). You sure you're typing it in right?
    The idea there is not to PRINT the command, but to POKE the PRINT command so that it becomes a LOAD "" command. Simple, and very, very elegant.
  • edited May 2007
    Self modifying code at its finest :-)
    I used to write self-modifying code in assembler. I still feel the temptation to do so (particularly to change the 'd' in ix+d instructions). Fortunately, I'm usually writing ROM code so spend the time finding a better solution than self modifying code :-)
  • edited May 2007
    Must have typed something wrong, cos it does work now - wonder where I screwed up then......
    Yes, very elegent!
    Oh bugger!<br>
  • edited May 2007
    If most of the keys don't work, what would you achieve by loading something?
  • edited May 2007
    zxbruno wrote: »
    If the numbers work (in menus, for choosing control method) then he can use a joystick in games (???)
  • edited May 2007
    In our electronic parts stores one can buy a conductive glue. You can find such a thing, it perfectly fits for rubber keyboards repair. I used such a glue to repair rubber contacts on my Amiga keyboard. Very good thing if you remember two rules:
    1. Never try to wash the rubber with water! It covers the graphite conductors with some kind of non-conductive tape after drying (this covering consists of non-organical substances solved in the water). It will be rather difficult to remove that covering. Use an alcohol to clean contacts!
    2. The rubber contacts with pads on the PCB. They also can be covered with graphite or something else like this. Never try to remove this covering even if you think it's damaged! Naked metal tends to be covered with oxyde with time, this will prevent your keyboard from working.
    During my first experiences i've violated both rules. Please beleive me, it's a pain to restore the things after that. And it never worked flawlessly after that, requiring maintenance every several months. :-(
  • edited May 2007
    Exactly!!! :D
    I will order a mebrane...I am too old for being a MacGyver :)
  • edited May 2007
    You can buy a new membrane and many more Sinclair related items from Sintech (Germany):
    http://sintech.hitech.cz/
