Mad Martha 1 & 2 incorrect type?
edited May 2007 in Infoseek database
Mad Martha and Mad Martha 2 are listed as Arcade:Adventure but shouldn't they be listed as Text Adventure?
Skarpo
Post edited by Skarpo on
  • edited May 2007
    I did an Advanced Search in Infoseek for games of type Arcade:Adventure and this game popped up but then the listing has it of the correct type Adventure:Illustrated
    And this one! (Text illustrated)
    And this one also! (tactical combat)
    Hmmm ... what's going on?
    OK ... here are the steps I took, indicating only the fields I changed:
    Infoseek Advanced->
    Year = 1985
    Type = Arcade Adventure
    Show Screenshots [ticked]
    The abovementioned games (along with a bunch of other ones) were listed as being Arcade Adventure but then their listing indicates something else.
    I haven't look at all of them ... if I bump into this again should I list it here? (I've bumped into a [strike]few[/strike] many more now)
    Skarpo
  • edited May 2007
    PS Just a feature request. In Advanced Infoseek one can search for games with certain scores.
    How about being also able to search for games which have not been given a score while searching with games of a certain score?
    I did a search for 1985 Arcade Advneture games with a score higher than 5 ... but I also wanted to include games which have not been given a score.
    (Or should I just stick to doing two separate searches?)
    Skarpo
  • edited May 2007
    Skarpo wrote: »
    They do both have little arcade games hidden away within them, but as they're primarily text adventures with some location pictures then I'd suggest Adventure: Illustrated as the type.
  • edited May 2007
    Skarpo wrote: »
    I'll try to explain how this happens.
    Internally, Infoseek uses the types I assign myself, from a rather limited set.
    This is the same set you find in the advanced engine options.
    Now, because the set is limited and SPOT (and now SPEX) offer a much finer grained list, I let SPOT override my type when displaying an entry - so this is not actually used, just displayed.
    There are indeed a number of errors in the types I assigned. The ones you listed have been adjusted now.
  • edited May 2007
    Alright, both titles have been adjusted.
  • edited May 2007
    Skarpo wrote: »
    Ohhh, that's sneaky, inserting an unrelated question in a thread :lol:
    Your proposal makes sense, but I'm afraid would make the interface more complex. Hence, I'd prefer to let you do 2 separate searches instead.
    That said, I'm of course willing to reconsider if more people think it's a good idea.
