Quazar - Celebrating 27 years of Developing for the SAMCoupé Hardware, Software, Magazines and more for the SAM Coupé Website:www.samcoupe.com Twitter:QuazarSamCoupe
How do they do that. How to they keep the brush stokes and detail consistent from the outer edge to the inner ege where one peice of work meets the next??
In the second pic, its easier to see how its done, when one picture joins to the next. Sometimes the colours dont quite match up, and you can see the joins. The first one had me fooled though.
What I mean is how to they pait each image?? is it if it were a flat image you would see less detail towards the center of the image as the astist would have to draw things allot smaller in the middle of the image as the would the outer ege of the image.
However, as far as we see things they are all the same size??!!?? How's that done??
Or are they not paining each part on a flat canvas.
And the display code just draws each rectangle to fit inside the hollow of the last...
Necros.
ZoomQuilt 2 was finished earlier this year - http://zoomquilt2.madmindworx.com/
Website: www.samcoupe.com
Twitter: QuazarSamCoupe
A.
