YANTG (Yet Another Name That Game)
Hello, all..
I'm going through some Spanish covertapes, and found this game..
I KNOW I've seen this before somewhere else..
You're in a maze, and you have to reach the exit before a giant floating "M" catches you.
Ring any bells?
Toodle-pip!
Gerard
Ring any bells?
Toodle-pip!
Gerard
Post edited by hackersanon on
http://www.worldofspectrum.org/infoseekid.cgi?id=0014919
I could be wrong, but I think(?) the version I saw perhaps had a large "A" chasing after you, though maybe not?!?
Toodle-pip!
Gerard
If I had something which could search ZIP files I could check for the CODE start address in the TTFn TAP archives, which should find it, but I don't have anything to do that. I'll see if I can find some suitable utility somewhere, if no-one comes up with the answer.
http://www.worldofspectrum.org/infoseekid.cgi?id=0001648
The Spanish one is messed up, though, as I can walk through the walls in numerous places and I can't pick up the disk - which problems don't occur in the original Rabbit version.
Still, it's prompted me to finally get a ZIP file search utility, which I've been intending to do for years.
Toodle-pip!
Gerard
