Maziacs Instructions...
Does anyone have a copy of the actual Maziacs game instructions that they can scan for me?
I want to compare them with the instructions for Mazogs.
Mazogs actually seems to be the more advanced game, with the inclusion of the tactic of "Mazog Pushing" - that is, they can't attack from above, so with care they can be 'pushed' out of the way so the player can reach a sword, etc.
I don't remember Maziacs having that...
EDIT: The text file on WoS isn't detailed enough.
Andrew
Andrew
Post edited by andrew_rollings on
I can check the inlay against what's on WoS if you like, see if there's any further detail to add.
Any chance you could compare the instructions against those found here for Mazogs?
Mazogs apparently had more depth: e.g. Mazog Pushing...
http://zx81stuff.org.uk/zx81/info.php?path=/zx81&sub=inlays&root=Mazogs&file=.Instructions1.jpg
http://zx81stuff.org.uk/zx81/info.php?path=/zx81&sub=inlays&root=Mazogs&file=.Instructions2.jpg
Hmm that's right... I think the instructions are in-game... ah, then problem solved :)
Andrew
