Anti Virus, Internet Security Application
Can someone reccomend me a good anti-virus / internet security solution?
I was just about to buy Norton IS 2007 then I read the reviews on Amazon. Looks like I'm going to steer away from using that one.
Anybody got any reccomendations free or otherwise?
Scottie_UK
Scottie_UK
Firewall - Get a router
Spyware - Spybot Search And Destroy and Adaware (get both).
I've got McAfee virus checker and Firewall.
Also use Spybot and Ad-Aware to scan
Or Comodo (very good - though takes a while to "train"):).
And make use of the "Teatimer":D
Also.... Run ccleaner occasionally.
Anyone had expreience with Kasperspy?
Scottie_UK
Nope, too busy using very good free software! :p
Be wary of expensive commercial virus scanners and anti-spyware programs that claim to detect more than anyone else's. There's more than a few conspiracy theories that suggest these "find" stuff that isn't there just to make you feel you've spent your money wisely. And several expensive ones have tested as worse performing than cheap/free ones.
Don't forget, few of these things prevent the virus/spyware getting on your machine in the first place, they just tell you about it after the fact or limit the damage. Nothing can replace good practices to prevent problems.
I second Starglider's suggestions (particularly get a decent router with a firewall) of free solutions. You can also still use a software firewall to have better control of outgoing traffic.
I personally use:
Virus scanner: AVG free.
Anti-spyware: Spybot & MS Defender.
Firewalls: Router & Comodo.
I hardly ever run scans and I've not had a problem... Yet.
I have read the reviews on the Web and I'm going to go with KasperSpy 7.0
I got three Licences for ?25 wich aint bad. I plan to use two licences on a dual boot machine I am soon to build and the other on my laptop.
As for a Firewall, I use a NetGear router/asdl modem combo which seems pretty good a stopping the crap getting in. But mybe I sould also install Comodo.
Thanks,
Scottie_UK
I use Sunbelt Kerio Personal Firewall, but I guess router is better
I second that :)
It's generally not a good idea to have two firewalls running at the same time. I have my router set up nicely from my Netgear router and have no troubles at all.
However, having just put my router firewall through Shields Up! and finding that it has passed all the test with flying colours, I wonder if I can drop Comodo entirely. Any suggestions?
i have comodo running but find it way too strict and cant seem to add my utorrent to it so it blocks most of the traffic, so when im running utorrent i close comodo and have M$ firewall running so i get better traffic, although ive recently started getting a problem thats scuppered that plan :(
now when i close comodo and run utorrent, my connection freezes up after a time
i really really do need to reinstall windows, but cant be arsed tbh :(
I also use another application called Crap Cleaner which gets rid of all the unused files lying around the hard drive. It's a really handy application that everyone should use.
I've been using Norton for a few years now, but I'd say to stay away from it. It's a massive system drain, plus, it's just let a moterfucker of a virus through that has made my old pc useless to the point where I have had to take it in to get lookd at professionally. Norton was set to it's highest settings too :(
At work, virus checkers have done more damage than they've actually prevented. On two occasions, Symantec has quarantined bits of the W2K3 Server Resource Kit - it's a good job we weren't using those parts as part of an internal script. Symantec has also quarantined Windows system files in the Chinese version of Windows, causing machines to be unbootable.
The only virus infection we've seen wasn't even detected by Symantec. It happened in the days before we had W2K3 server for the desktops and group policy, and someone connected their laptop directly to the internet (something that group policy now prevents). Symantec couldn't detect this particular one until a good week after it happened.
So it's been worse than useless. Keep your system updated, don't download random crap, when you download non-random crap verify it's really coming from who you think it's coming from, don't use Outlook Express, turn off HTML email, and run a firewall. Don't run as administrator.
ITYM Kaspersky. :p
It's the one my email provider uses to scan mail (Full and Enhanced accounts only, sadly)...
misteaksmistrakesmisyaleserrurs— oh, sod it.I think I might upgrade to Avast...
misteaksmistrakesmisyaleserrurs— oh, sod it.I don't have any AV/Spyware software installed now its all in a hardware USB linux computer. Its increased the speed of the system by around 25% - 30%.
Theres always a down side,... uploading very large files 32Meg - upwards, can be a bit slower.
The best part is you can unplug it when you don't use the net, or use another machine take to yoggie with you.
Or you don't run MS Office. MS Office is far too 'featureful' and expensive for home use. Even though we can get a home license based on work for about 17 quid, I'd rather use OO since it does everything I need it to do and runs on my desktop system (which Office will not, without farting around with Wine).
Antispyware: SuperAntiSpyware,
Firewall: Zone Alarm
also, whilst you're downloading, you might want to consider downloading at:
Irfanview: best graphics viewer ever,
Firefox: (I love it, some people prefer Opera, you choose, but don't use Internet Explorer),
Mail Washer: Detects and deletes spam e-mail,
VLC Media Player: To play all video formats - I prefer Zoom Player, but VLC playes everything I've ever seen,
MP3Gain: Equalises the volume level of your mp3 files,
WinAMP: You've probably got this already, but if not the you should get it, it's a very good mp3/wma/etc music player,
Foldersort: Sorts the music on an mp3 player into alphabetical order.
Everything in this post ifs freeware, so it won't cost you a penny to try.
Adware usually just sends you pop-ups
Malware is malicious, actually modifying your system (like the Vista Antivirus 2008 one above, which messes with your Security Centre in XP...)
* Fawlty Towers anyone?
