DVD-RW angst
I've been recording some old videotapes onto Sony DVD-RW discs, and it went quite well. However I've finalised the discs and have discovered that they won't play on any other DVD player except the one I used to make the recordings. As you can gather, this is something that annoys me a great deal. Can anyone suggest what could possibly be the reason for this, and better still, a solution?
Post edited by Spector on
If you have the cash you could buy a different machine.
Could be the brand of disc you've used. Try one single DVD-R disc only and see how you get on with that.
Buy a new dvd burner? I had a similar issue once and it was down to the crappy burner.
