DVD-RW question
I've made up a DVD-RW disc with various old VCR clips, but when I come to copy it onto my PC's hard drive as backup, it comes up with a message after a minute or so:
"Cannot Copy VTS_01_1: Invalid MS-DOS function."
What that means is that I can't make a backup of this disc, which effectively makes it useless, because when it stops working in five years or so, that's it.
What the hell has MS_DOS got to do with it anyway, and is there any way around this problem?
I hate DVDs, I really do.
Post edited by Spector on
Check your build settings to make sure that joliet is enabled and the other various options that I can't be arsed to go and check right now ;)
Download DVD Shrink and open up your disc and save it as an ISO. If that works then you are fine as you can then obviously copy it the normal way by burning an ISO but try that method first.
All disk-operations in Windows has MS-DOS as the active element. File-copying in windows (cut/copy and paste) is done by executing underlaying MS-DOS commands.
Your disc is a DVD video disc, so try copy it using DVD-Shrink. It's a free program. You can find it at http://www.doom9.org/ and many places elsewhere. DVD-Shrink can also copy copy-protected DVD's, and it shrinks the contents of the original disc, if needed, so it will fit on a DVD-R/RW disc.
Nope, not by a long way. That might have been sort-of true in the days of Windows 3.1 (or 95/98 at a pinch) if you stretch the definition of 'MS-DOS command' far enough, but certainly as of Windows 2000/NT there's no component of the system that can be described as MS-DOS.
Not quite, When you name a file both the long name and a truncated 8.3 versions are saved. Each file is stored on disk (hardrive, floppy, Flash Drives) utilising the old 8.3 name and the larger name in its directories.
This has nothing to do with DOS, it's about disk Formats. Done so so that the disk is able to be read by systems that do not understand or impliment large file names (i.e. Legacy systems).
I know this is true of FAT12, FAT16 and FAT32 disk formats. I'm not sure about others though (such as NTFS).
