Is there any incompatibility with Hysteria and +2A models?
Well, that's basically it :)
Thanks in advance
Thanks in advance
Post edited by Ivanzx on
<a href="http://rincondelspectrum.blogspot.de/" target="_blank" rel="nofollow">http://rincondelspectrum.blogspot.de/</a>
What you say its exactly what happens to my copy of Hysteria, when it finishes loading, the game crashes or something and the csreen turns completely black... :(
In fact, I was always disappointed with SOTB on ZX, Gremlin's port (spider soft?) is rather poor. If the game would be ported with Hysteria's engine, it would be much much better.
I found this +2A/+3 fixed version which may be of use:
http://www.zshare.net/download/52323596e5358d/
If you want to get an original version working then all you have to do (providing you have a version that uses the standard Spectrum loader -- if it has a custom loader than you're out of luck for the moment) is MERGE the BASIC loader, add POKE 44454,59 just before the RANDOMIZE USR statement and that should do the trick.
Cheers
1. Hint of THGTTG (or am I way wrong here?)
[strike]2. Erm ... the game just seems to hang there, i.e. the last message
"...last moment of your mission and..."
Well ... is there something more to the message? It doesn't go to a second page nor does pressing any buttons work.[/strike] Never mind ... I must have a crappy keyboard ... pressing SPACE seems to work.
I guess it must do! It's so long ago that I just can't remember!
