captain pytron
hello
i am trying to map this game but i am stuck.i have gotten to the 3rd floor,but now nothing.it says in the magazine covertape notes that you are to hold objects and then insert batteries,but this has got me stumpted(or maybe i have not found the correct object).
http://www.worldofspectrum.org/showmag.cgi?mag=SinclairUser/Issue099/Pages/SinclairUser09900004.jpg
does anybody know how to complete/any tips for this game would be great.
thank you
colin
thank you
colin
Post edited by ladderman on
If I remember well, it's quite hard game.
http://www.speedyshare.com/166238740.html
Hope it helps and you can make it further
ralf,the RZX of this game you sent is excellent and will help me get further into mapping this game.does anybody know why in the magazine covertape page,the main sprite is 2 colours but in the game the main sprite is only 1 colour,why the difference?.thank you
colin
ralf,if you are interested go to the the far right of floor 2 and hold explosives then use a battery,then use the combined explosives/battery.this blows the door open letting you get the navigation kit and a disk.use disk on the left door
on floor 5,keep going left and you get to the spaceship.after that i am stuck.if you get any further than this,please post here and let me know.thank you
colin
OK,this game has been solved.after the hints in my last post use the yellow pass in the rocket to finish the game.map finished,2 to go.all the best to everyone in the coming days.thank you
colin
I also dicovered it and was about to tell about it. It's a little bit dissapointing,that it's the end of the game. A lot of unnesessary objects scattered everywhere.
And ladderman, I'd check your monitor or settings. The pass you use is green, not yellow.and main sprite is 2 colors (cyan pants, white torso) like in screenshot so maybe you're missing blue composite of colors palette.
Anyway congratulations on completing this one and keep up the good job with the maps. They are great.
