Another important Windows tip
Following on from the Unlocker thread (Entitled "A vital piece of software for Windows is here "), here's another occasionally invaluable tip for people who use Windows; today, for the first time in a long while, a program that was running on my PC (an audio format converter) wouldn't reappear when I'd minimised it, instead remained invisible, and when I right clicked on it's Task bar icon I got the "EXIT, MAXIMIZE, MOVE" etc menu, but nothing would bring it back. Even exiting the program then reloading didn't help, as presumably the program saved it's on-screen co-ordinates when exited, and also presumably those same co-ordinates were somehow offscreen.
I've had this problem before, but very rarely, and usually exiting and reloading the program works, but not this time, so I googled the problem, and found the solution at:
http://www.answerbag.com/q_view/467589
the solution being:
"If you press ALT-SPACE and M you can then use your arrow keys to move the window back into a viewable area of your screen. Alternatively, ALT-SPACE and X will maximize the application which will make it visible again too but if you don't usually run your apps maximized you'll probably have to retrieve the window again next time you close and re-open it."
following this advice, I used ALT-SPACE and M, then used the arrow keys (the mouse didn't help, only the arrow keys solved the problem) to bring the window back on screen, and now it's fine.
I just thought I'd post this, in case anyone else encounters this (thankfully infrequent) problem and doesn't know how to solve it.
the solution being:
Post edited by ewgf on
moving the mouse doesn't move it unless you use an arrow key once. once you have moved it one step with the arrow key, the mouse movement then moves the window.
I laughed when my friend came back after loaning the disc and said my computer's fucked, I installed....I butted in and said "Twins media player? Yeah I should've told you about that" :D
misteaksmistrakesmisyaleserrurs— oh, sod it.
