Any tax experts in?
If I have a private pension that's contracted out of the State Earnings Related Pension Scheme, does that mean I'm entitled to pay reduced rate of National Insurance, as I'm not meant to be paying into the state system?
If not, what's the point of a private pension contracted out of SERPS, exactly?
Should I look at getting a different type of pension?
Cheers.
Cheers.
Post edited by Vertigo on
NI payments?...not affected.
spend the extra 100 notes on crack, you wont live to see 50, so it's worth it. :)
I really foo'd up here :(
I also didn't realise that when you die, and your partner dies. Your pension goes to the provider - or something like that. What a rip. As soon as I can I'm taking as much out of the pension in a lump sum as I can.
Totally pointless then...also, the older you are, the less point there is in contracting out..if your 45+...then it's actually very detrimental.
To get something approaching a decent pension, you'll need upwards of 300/400 pounds per month.
Thanks for the advice.
tax free savings ftw! :wink:
