Wiki help
Howdy,
I want to put some sort of wiki up on my web space, but as the server it's on doesn't support the most up to date versions of SQL and PHP, I can't use anything like mediawiki which was my first choice. Getting the software versions updated is not an option as I don't rent the space and having already asked they refuse to do it anyway without an upgrade of the server account, which isn't mine.
Are there any wiki-type softwares that I can use online (I'll be the only editor of content) that don't require this sort of database background?
I just want to use a wiki as I hate blogs (already tried to use one for content updating before and it was a pain in the arse) and wikis are easier for just throwing content up there without having to heavily code and make things wonderful for all resolutions and stuff like that. I just want to shove content, text and graphics, up onto the internet instead of wasting my time with the back-end technicalities (that's reserved for the missus) of the html and all the boring shit.
Basically I want to write and publish, but be able to cross-link pages too, which is why a wiki seems ideal.
I don't really want to rent my own web space.
Anyone who can understand the stream of crap above got a recommendation?
Post edited by Vertigo on
Very handy. Very handy indeed.
You're my hero :)
I honestly didn't think it would suggest that many. I would consider "tweaking" your answers to get the number lower, if you can.
Also, have a look at OpenSourceCMS - you can think of it as a "try before you don't-buy" way of checking out various content management systems. They have about half-a-dozen Wikis I think, not checked to see if they cross-ref with your list or not, but it features a couple of the "biggies". Let's you see what you're letting yourself in for ;)
Adding PHP to your requirements gets the list down to a much more manageable 10 Wikis: BoltWire, DokuWiki, ErfurtWiki, Giki, LunaWiki, MoniWiki, PhpWiki, PmWiki, Triki-Wiki and Wikepage.
Of those, I'd likely pick out DokuWiki and phpWiki as starting points for a comparison. But again, that's my personal preference.
Alternatively, you can specify a few more options in the Search.
