Point&Click humorous adventures for Windows XP?
Any recommendations for new(ish) Point&Click adventures for Windows XP in a cartoon or comedy style? I'm thinking of updated variations of games in the style of The Secret of Monkey Island or Simon the Sorcerer. There doesn't seem to be much to choose from of that sort at present. I've got Discworld Noir but it says on the box that it doesn't work with WinXP. I've been thinking of getting Journey to the Moon as well.
Why not download scummvm as you can get a few games as freeware from the site
The engine
http://www.adventuregamestudio.co.uk/
The games
http://new.bigbluecup.com/games.php
also id recommend the commercial games sam and max and maniac mansion / day of the tentacle though youll probably need to use scummvm to get them running properly on xp but its very easy to do
and then I will never do!
I see that Normality is available as a re-release on WinXP, so I might try that. It seems that my best bet is the Lucas Classic Line of re-releases, such as Grim Fandango. I've still got a Win98 PC so they'll run on that if not on my WinXP PC. But these are all old games. Is humour not fashionable any longer? Thanks for the suggestions, anyway.
I think humour is very much fashionable (see Portal from Valve for example) but point-and-click adventures are not. :(
Also Daemon Tools if you want to run CD stuff quicker and better and without the spinning drive noise.
I know it's a shit game, but you wouldn't believe how fast and smooth and good-looking The 7th Guest is running from a disc image.
I still have a real working "DOS box" - a 15 year old 486 DX/33 PC - so I can play old games released on floppy disc on that. Unfortunately the CD drive doesn't work, and I've tried two replacement drives which won't work either, which tells me it's something other than the drive itself which is at fault, but what, I don't know. The odd thing is that it will play music CDs via the Media Player, but if I put in a CD with a DOS file system and try to read something I always get a "Disk not ready" error.
Anyhoo, as regards the DOSbox which you mentioned ... Some time ago I installed all my old DOS games (apart from three which had developed media errors) and backed up the directories to my Win98 PC. Would this DOSbox be able to run these games from their installed directories on Win98 (or WinXP)? Also, I have a few DOS-based CD games which I never got very far with (Ecstatica, Eye of the Beholder, Return to Zork) - these I could presumably install & run on Win98/XP with this DOSbox program?
Daemon Tools sounds like it would be useful for playing something like Ultima Underworld (I've got 1 & 2 on CD, but never even managed to finish the first one). I've found that Win3/95 CD games aren't a problem, as (apart from Lands of Lore 2, which uses a stupid non-standard screen resolution) all the ones I've tried will run under Win98.
Talking about drive noise, there's a number of modern games (well, less than 10 years old, anyway) which I've quickly given up on playing because they're constantly accessing the CD - even if I select the "maximum install" option and turn off all the audio features - so it never spins down. Apart from the noise, the disc itself gets really hot, which can't do it any good. This is another "kiss of death" game design flaw for me - but not something usually mentioned in reviews, so I end up buying some "brilliant" game before I discover how much it annoys me. Still, I usually wait at least 18 months - 2 years post-release before buying games, so I always get them cheap.
By the way, if you didn't like The 7th Guest, did you ever try The Legacy, which is another spooky mansion game? I thought that was a good game, but way too hard for me.
It wasn't the bit with the goat by any chance? Fiendishly difficult puzzle, but the clues are there.
I can no longer recall the specific problem. It was early in the game (which is why I was so particularly annoyed at getting stuck, and at the obscurity of the solution), so if I re-installed it and tried again I'd soon be stuck at the same place.
I've been reading some of the reviews on Amazon again for the Broken Sword games, and they all heap them with praise. I'm tempted to give the first one another go now, as the box is just under my desk here.
