Its basically audio modelling software where you build your own synth from Moog-esque components and then control it and play it by midi.
Its UI has a more realistic visual metaphor than most analogue modelling software, i.e. Reactor on the Mac. I found the learning curve of Reactor huge, but the learning curve of Vaz alsmost instant.
Could you share more details on what instruments you used, how you saved it (real-time or sequence), etc?
Thanks.
Keep up the good work.
I use a tool called VAZ Modular 3.6 by STL.
