What good (Windows) software is there to remove singing from songs? It's for a bloke I know who wants it for karioke, and he's not up on computers, so preferably software that's easy to use.
Thanks for any answers.
er, yeah a bloke you know. he he.
i bet you could download karioke songs just like you can for the real thing.
they must come from somewhere, and i bet someone will have uploaded them to the net. you'd be able to find the popular songs that people do. but if you, erm i mean your mate wants specific songs to sing along to then i can't help you.
I know, I'd suspect the same, if someone else used the "it's for a friend of mine" line. But in this case it's true, and if it was for me, then I'd probably just download the songs I liked, from the same cough sources cough that provide any other music on the 'net, instead of messing about with conversion programs.
I suspect if such software exists, it will cost $BIGNUM.
Absolutely. However, in making remixes of other people's stuff, I have noticed that a lot of stuff produced recently seems to be fairly easy to filter. For example, one of my last remixes was of a Jamiroquai tune from their last proper album (Dynamite), and all I was using was the "AnalogX Vocal Remover" plug-in for SoundForge which worked surprisingly well. In the past, I've found this plug-in to be fairly useless, but there are certain mixes/productions that it seems to be able to filter through quite well.
But yeah, beyond that, you're looking at parting with a fair wedge of dough, unfortunately!!
These things are probably a bandstop filter, perhaps with some code to make a guess at the frequency band where the voice lies. If the frequency range of the singing doesn't overlap the instruments too much, a bandstop filter will do the job.
But for everything else where a significant amount of the instrumentation is in the same frequency range as the singing, you'll also take out a big chunk of the instrumentation, or you'll not take out all the singing. To get better than that, I suspect you're going to need AI. Or, I suspect, use the intelligence of a human, for instance, playing the sung melody on a keyboard that's connected to the computer, at the same pitch so the computer has a fighting chance of knowing what part of the sound is voice.
scottie might know, he likes karioke.
:-P
http://www.youtube.com/watch?v=C_TR4po1Y9g
If you want software that does it well though, I agree with Winston.
Olanzapine will do the trick ;)
