Help using M3 ram
From the Multiface 3 manual.
Doesn't give any details whatsover, I guess its not a simple IN A, (191)?
I've been using the Multiface 128 ram for my own programs, now need to use +3 hardware to access the disk.
Thanks
6.0 The Use of Extra 8K RAM
The MULTIFACE's 8K RAM extension can be accessed and used for other purposes.
This, however, requires a good knowledge of machine code plus further
information on how to access the RAM extension.
Thanks
Post edited by FrankT on
IN A,(191) pages out.
My ZX Art Music Page
Carlos Michelis Theme
Nope, other way round ;)
Oops, yes, i've corrected above listing now. Thanks again, now to try and write a program to write to disk starting at cylinder 0/sector 0.
I'm attempting to write a program to byte copy a disk in its entirety. So I can get disks built with your excellent diskbuilder program onto my proper +3 disk/hardware via tape files with original hardware.
Probably already been done a hundred times but I want to do it for myself anyway. (probably because I wanted to do it when I was a nipper)
Cheers.
p.s.
Anyone know of areas in M3 ram that are possibly used and I should avoid? Or is it all free to use?
