Was joking :-) ... since it is really hard to display 3 colours per 8x8 square ...
Ok, now I am with you! :wink: Yes I know that the Spectrum can not really display 3 colours at once and AWM uses the trick with switching to the secondary screen at the right moment, but I still think it is quite amazing to see!
It goes very fast unfortunaly, it would be ever nicer if the screen was displayed a little slower, but perhaps it is for technical reason that it must use that speed?
the other video page could have something more interesting than just 15 colour pattern though, and you would actullay be able to see 4 colours per 8x8 square ;-)
Do you know if any other game/loading scheme did use this technique? Should it be possible to actually use in-game to create "sprites" och backgrounds with 3-4 colours per 8x8 square?
The only reason I can see is that the next block starts loading very quickly, so the screen "fade" must be done quickly too... no other technical reason there :)
Quite some games use this same loader and produce the same fading effect to show the loading screen... but in-game it would be REALLY hard to maintain the timing required to do this (since Speccy doesn't have video line interrupts like for example C64 has)...
If you mean loading different order it can be done in BASIC when you load line by line with 192 loaders.
If you do that, you might want to figure out a way to prevent the 'Bytes:' messages from scrolling the screen away faster than it loads :-)
(As a more sensible answer... no. The only tape load/save routines available from a stock Basic environment are the ones in the ROM, which don't support customising the order bytes are loaded/saved in - and trying to roll your own in Basic at the IN/OUT level would be several zillion times too slow. However, the custom loaders that other people have written in machine code don't necessarily require machine code knowledge to use.)
Some kind of "still-BASIC-mode" would be to have a BASIC program that includes some POKEs from DATA statements to make an almost similar copy of the ROM loader, but with different values for the border stripe colours.
Yup, the 2.50 mdr is slightly stuffed - the "run code" file looks to be fecked, but I think the rest of the files are good. Check out the "Alkatraz Utils.mdr" this seems to "RUN" with no problems - I'm not completely sure how to drive the whole package though. There is also a really unique assembler amongst this bunch of images, very microdrive friendly and looks to be a fairly slick 'custom' job.
Ah, right, yeah the other one works. It's not very self explanatory though :( At least you can have fun with the screen load designer though :)
Just finished writing this program to draw the screen line by line. Doesn't load from tape yet, just wanted to understand how to draw line by line first. Its my version of a colour test card.
Assemble in Spin, and run with,
1 RANDOMIZE USR 4e4
2 PAUSE 0
3 GOTO 1
Pressing a key undraws (?) the screen.
org 40000
out ($fe), a ; border black
ld hl, $5800 ; attribute address
ld bc, $0000 ; counter
colour: ld a, c ; get colour
and 71 ; mask
ld (hl), a ; poke colour
inc hl ; next attribute
inc bc ; next colour
ld a, b ; check if
cp $03 ; 768 bytes
jr nz, colour
ld a, (drawline+1) ; get screen poke byte
xor 255 ; inverse
ld (drawline+1), a ; poke screen poke byte
ld a, $40 ; top 1/3rd screen
pokethird: ld (screenaddress+2), a ; poke 1/3rd address
screenaddress: ld hl, $4000 ; hl = screen address
ld b, 8 ; b = line counter
startline: ld c, 32 ; c = byte counter
drawline: ld a, 0 ; a = screen poke byte
ld (hl), a ; poke to screen
inc hl ; next screen address
dec c ; decrease byte counter
ld a, c ; check number of bytes
jr nz, drawline ; continue if 32
dec b ; 1 line drawn
ld c, 224 ; 224 bytes to next line
nextline: inc hl ; next screen address
dec c ; decrease counter
ld a, c ; check if 224 bytes counted
jr nz, nextline ; continue if hl = next line
push bc ; temporary delay loop
ld bc, $1000
delay: dec bc
cp b
jr nz, delay
pop bc ; end delay loop
ld a, b ; check if
cp 0 ; 8 lines drawn
jr nz, startline ; if not draw next
ld a, (screenaddress+1) ; get lo-byte of screen address
add a, 32 ; add 32
ld (screenaddress+1), a ; poke result back
cp 0 ; check if 1/3 screen drawn
jr nz, screenaddress ; draw next character line if not
ld a, (screenaddress+2) ; get hi-byte of screen address
cp $50 ; if bottom third complete
ret z ; end
cp $48 ; if middle screen complete
jr z, bottomscr ; get bottom screen address
ld a, $48 ; middle 1/3rd address
jr pokethird ; draw middle screen
bottomscr: ld a, $50 ; bottom 1/3rd address
jr pokethird ; draw bottom screen
Does the same thing. Assembles with pasmo and likely to in SPIN without many changes.
Assembles in Spin fine as is. Much better than mine, though mine was a first ever attempt at drawing to the screen. Now I know how it works I can learn quite a bit from your version. I've written another that prints a screen loaded to 32768 (binary .scr), with 1 line of attributes printed after 8 pixel lines (character line). But its displaying only in character lines at a time instead of pixel lines.
Can't work out how to draw 1 pixel line in colour and keep the paper black.
Sometimes I really pity myself, I see the code and can't help myself but automatically start thinking how it could be improved further even if I really don't want to. :roll:
Do you mean draw 1 pixel line with for example red and white PAPER and INK and keep the undrawn pixel lines below still black?
That is possible, see the Auf Wiedersehen Monty and Death Wish loaders discussed earlier, but I suspect it would be very difficult to code, as you have to switch between two screens in 128k mode at the exact right moments.
Where's Woody's code gone? I didn't save it and now I want to study it. :(
I'll have a look at Auf Wiedersehen Monty's loader, but I wanted it drawn whilst loading, not after its loaded like the gremlin loader.
The Auf Wiedersehen loader is subtle but VERY clever.
It is 128K only (requires careful switching between the two screens).
And brill music in the game of course.
Do you have other examples of games with on this loader? I think I only saw it in AW-monty what I can recall, what be interesting to see others.
Avenger: http://www.worldofspectrum.org/infoseekid.cgi?id=0000351
Future Knight: http://www.worldofspectrum.org/infoseekid.cgi?id=0000351
Death Wish 3: http://www.worldofspectrum.org/infoseekid.cgi?id=0001299
These are the ones I remember :)
Nice! Thank you!
Not sure if that counts..
1 RANDOMIZE USR 4e4
2 PAUSE 0
3 GOTO 1
My ZX Art Music Page
Carlos Michelis Theme
Thanks.
Source code for the assembler here
http://retrospec.sgn.net/users/tomcat/yu/ZX/Cracks/CosmicWartoad.zip
http://retrospec.sgn.net/users/tomcat/yu/ZX/Cracks/Nomad.zip
And one where it loads it from both sides at the same time :
http://retrospec.sgn.net/users/tomcat/yu/ZX/Cracks/TurboEsprit.zip
You can see them all in your browser (Click on Speed: Full for faster loading):
http://retrospec.sgn.net/users/tomcat/yu/startzx.php?snap=/users/tomcat/yu/ZX/Cracks/CosmicWartoad.zip&type=48k&width=760&height=504&title=CosmicWartoad
http://retrospec.sgn.net/users/tomcat/yu/startzx.php?snap=/users/tomcat/yu/ZX/Cracks/Nomad.zip&type=48k&width=760&height=504&title=Nomad
http://retrospec.sgn.net/users/tomcat/yu/startzx.php?snap=/users/tomcat/yu/ZX/Cracks/TurboEsprit.zip&type=48k&width=760&height=504&title=TurboEsprit
Impressive!
