Machine code help pls: LDI example
edited December 2008 in Development
[deleted]
Post edited by Unknown User on
  • edited November 2008
    No, it doesn't look like a typo.
    "Load (DE) with (HL)" means copy the contents of the address pointed to by HL to the address pointed to by DE - it doesn't affect the values in the registers DE and HL. So:
    DE=9, HL=15, BC=24
    LDI copies the contents of address 15 (HL) into address 9 (DE), then increments and decrements, so:
    DE=10, HL=16, BC=23
    SkoolKit - disassemble a game today
    Pyskool - a remake of Skool Daze and Back to Skool
    SkoolKid is correct, except for his first sentence :-)
    Yes, it is a typo. The end result of an LDI will indeed be DE=10, HL=16 - not HL=10, DE=16 - as per the reasoning you've both given.
    * blinks *
    * laughs *
    Hey, it's still early here in Canada. :)
  • edited December 2008
    JimTheBrit wrote: »
    My question: Won't the Found code also execute if BC=0? After all this sets Z=1 too
    Nope, a CPI instruction only sets/resets the zero flag according to the result of the comparison - the value of BC doesn't enter into it at all (which is why that bit of code does an inc c / dec c later, to force the zero flag to consider the C register at that point).
    If you like, you can think of CPI as internally doing a DEC BC instruction, which doesn't touch the zero flag either. (Or you can just shrug and accept that that's the way CPI works...)
    JimTheBrit wrote: »
    Thanks for the replies, that clears that up!
    Here's another query though, this time regarding CPI ...
    CPI compares A with (HL), incs HL and decs BC (the counter). Here's the example given - it assumes the length of the block that's being searched is less than 255 bytes long:
    Search CPI
    JR Z, Found
    INC C
    DEC C
    JR NZ, Search
    NotFound .......
    Found ............
    So Found is jumped to if Z is set by the comparison and NotFound is executed if Z is set by BC=0 i.e. all the bytes have been checked.
    My question: Won't the Found code also execute if BC=0? After all this sets Z=1 too and will cause the JR Z, Found instruction to jump. I can't see how NotFound will be jumped to.
    Edit: The post has thrown the code segment formatting out a little :(
    By heart,
    CPI set Z if A=(HL) and sets P-vlag when BC=0
    You can do this
    CPI
    JR Z,AISHL
    JP PE,BCZERO ; could also be PO
    Dr BEEP wrote: »
    By heart,
    You can do this
    CPI
    JR Z,AISHL
    yup,
    LDI/LDD
    CPI/CPD
    are same family and set P/V flag to zero when BC==0
    JP PO, xxxx jumps if P/V is zero
    JP PE, xxxx jumps if P/V is set
