TZX Vault Unique ID
Hi dudes,
when the CAPS IPF format was created, there is a unique ID field within the file, as well as revision info (not that there has been any revisions yet). thus all images preserved are given an ID number
does the TZX format have any such facility? if so, i truly beleive that the TZX vault should consider using it.
why? right now the preservations are referring only by name, several games get redumped and rereleased, it would be nice to know that there is a uniqie ID for each TZX file, and a revision number used will ensure that we dont keep older (and thus incorrect) TZX files.
like it or not, the TZX vault / STP team has now taken the central responsibility of preserving spectrum games, i think you should keep an organised tab on it :)
apologies if this is already in place, i just havent seen any evidence of it (possibly my ignorance of course)
your thoughts please
Post edited by Interceptor on
The newer files are uploaded onto the server and are labelled with an "Updated" icon to indicate this.
This has been in operation for quite some time now....
If you're worried about not having a completely up to date set of files, .tzx vault CD's are available for ?5, which also helps fund further tape purchases.
Steve
"like it or not, the TZX vault / STP team has now taken the central responsibility of preserving spectrum games, i think you should keep an organised tab on it :) "
Well, I do try to keep everything organised. The database which is maintained in the background helps, it includes a field which records the date that an entry is created / amended in the database. This field is used when inserting "New" and "Updated" icons but not used elsewhere.
Of course, this "responsibility" has only been inherited through time because there hasn't been a .tap / .z80 update for quite some time. Sadly, there aren't enough hours in the day for Martijn ;)
Martijn, would this be a good time to think about outsourcing this job? Maybe getting someone else on board with co-maintainer access could help clear the decks a bit?
Steve
There's a nice twist on history! :)
The STP team was formed with the express purpose of being the preservation team. It was there already when non-TZX updates were still done regularly. The fact the results are published on the TZX Vault is because I couldn't keep up with this project at the time. Some 2 years ago we decided to keep it like that and import the Vault into WoS using new automated database tooling I specifically wrote for it - the one you use for the Vault included :)
Of course I can only confirm that there are indeed not enough hours in the day for all projects. My available time hasn't really gone down (I'm still at 30 WoS hours a week), but the amount of projects and their pace continues to increase. Can't say I'm sad about that, although indeed some projects don't progress at all anymore due to it. Unfortunately the non-TZX archiving fell victim...
That might be the best solution (after all, several other projects have been outsourced as well).
I do that for the SDP project releases,
so that they will match by CRC.
I did make a Vault DAT but only for my own auditing purposes.
Regards
Andy
[ This Message was edited by: Andrew Barker on 2004-02-17 15:28 ]
i can forward you some snippets or a large discussion on this that's been had recently...but i warn you, it's vile and hideous :)
i'll remain convinced on my unique ID theory, but if it doesnt suit you...fair enough :)
