Using a tape drive for Spectrum +3
Could I just use any tape drive? I only have a sony walkman, really. Could this work? Also, how would I load up it up on the +3? Do I just set the tape going, not put a floppy in the drive and then press enter on the +3 loader?
Thanks.
Thanks.
Post edited by wootlanter on
Or to elaborate - you need a cable that will connect the tape deck to the tape/sound socket at the back far left of the +3. (The Spectrum shop on ebay sell these).
Whether or not it will work depends largely on how much volume the walkman can pump into the +3 - it may be too quiet (as it's stereo).... Only real way to know is to just try it!
You can then play the .wav out of your PC and record the sound on your tape desk.
You could use your PC's sound output with an external amplifier to play the .wav directly into the Spectrum. It might work without the amplifier but probably won't.
Best to use a mono cable so losing 1 audio channel.
Many thanks! :smile:
Enter as a direct command: LOAD "t:" [Enter]
All loading now defaults to the tape device
Likewise, SAVE "t:" defaults all saves to tape
Use the normal syntax - LOAD "filename" and SAVE "filename"
sorry for this question but can I load/save programs into/from external tape-recorder via "sound/tape" port on Spectrum +2? (Well, +2A actually).
I'm very fresh in 128K world.
The +2A tape/sound socket is output only.
(One day I'll put up a web site with just that sentence in BIG letters - as there is a lot of confusion about this on the boards) ;)
The best way of loading from an external source is to use a tape courier device (a dummy tape with a stereo connector on the end). That works really well and doesn't involve taking the computer apart or frying the ULA.
If the tape deck doesn't work you can always solder to the PLAY and GRND sockets on the motherboard (They are clearly marked on a +2A so it's hard to go wrong). But you need to be careful with volume as there is nothing to protect the ULA from getting fried when you do it this way.
Finally :D...... Somebody who understands!
Only teasing ;)
argh. I suspected that.
Still, I hoped, considering +2A was actually +3 without fdd, that there was the same 'tape' trick like in +3.
pity.
thank you for the info.
