Maze Mania - How did they do it?
Hi,
I was looking at the game "Maze Mania" by Hewson Consultants, written in 1989. The game can be downloaded from here http://www.worldofspectrum.org/infoseekid.cgi?id=0003092
I was looking to write a large map based game, similar to "Fred", or "Magic Pockets" (PC - Bitmap Brothers) and wanted to develop a method of drawing the blocks quickly and transferring them with no flicker etc.
The main screen is 28 chars by 16 chars in size, moving 1 char in all directions.
Do you think each frame they
1. Drew the blocks to a back buffer
2. Drew the sprites in their correct positions
3. Copied the buffer to the main screen
It seems so fast on Maze mania. I think some of it is an illusion, in that the sprites move a few pixels at a time, while the main character moves 1 char at a time, giving quite a nice smooth movement effect, even though the map is moving 8 pixels at a time.
It seems like it is moving about 25 FPS but it could be less.
I would be interested in your ideas about the best way to implement this.
In the "diagram" below, I am trying to show how I think this could work.
1 = Backbuffer 32x24 chars. Each block in (4x4) and are drawn on 8 columns x 5 rows offset depending on position
2 = The centre 28 x 16 chars are copied
3 = screen
I am wondering if there is a better way by calculating offsets for the blocks/sprites and to draw directly to the screen etc
3 = screen
Post edited by robpearmain on
let me explain:
galactic gunners (which is very different kind of game) has backbuffer with terrain and scroll it by one pixel.
the scrolled terrain is then copied to the screen (area 24x16 chars) and copying is done just behind beam generating screen (floating bus check). when it is finished the beam is somehere in the bottom border. it leaves at least 15000 T for drawing sprites directly into screen (probably much more if sprites are sorted somehow)
i think Terra Cresta uses something similar (but we have local expert on Terra Cresta so ask him)
on other side, i believe that Probe's char scrollers like Dan Dare III, Savage really constructs screen on char basis for every frame.
another idea is put the sprite to the backbuffer and copy backbuffer to screen then lift sprite (means replace it by original background), scroll background a and draw tiles on edges.
i would recommend to count frames in Mazemania and you will see (i know that U.N. SQUADRON runs on 12.5 fps, i believe CHRONOS has same framerate. both are rather decent games)
this is interesting thread but i have to be brief as i have no time. may be later.
Looking at the Maze Mania code in more detail, I think they do a backbuffer copy, but it is pretty smart.
I think they have a table for each of the lines (18 x 8 = 144 lines) containing the source address and the destination screen address. The SP is pointed to this table, and the values are "popped" into HL and DE. Then 28 x LDI's are done to copy from the source to the destination.
I have the pseudo code here (After halt) based on what I can see in Maze Mania
An example of the "table_of_source_and_dest_addresses" then looks like this:
Where the first 2 bytes are the screen destination, the next 2 are the backbuffer (in this case starting at $E500)
This takes about 79,000 T-Cycles, so I reckon with some optimised Tile Writing and Sprite Code I could get 50/3 = 17 Frames per second, or at least thats my goal.
So, I think I will see how I get on with the following...
1. Copy Tiles to BackBuffer
2. Copy Masked Sprites to BackBuffer
3. Copy BackBuffer To Screen
The scrolling moves in characters, and it takes about 3s to scroll the width of an entire screen. That's 7 blocks, or (7x4=) 28 characters, in (3x50=) 150 display frames. That means it's taking about 4 or 5 frames of the TV display to refresh, around 10-12.5 frames per second. That's more than enough time to redraw the entire screen from character blocks. And given that it's only displaying a small windowed screen (28x16 characters) that's enough time to redraw the background, copy the sprites onto it, then copy the whole lot to the display.
In fact, they're probably not re-drawing it from blocks. Look at the screen border graphics; 2 characters wasted on each side, and four at the top and bottom. So if you had a back screen that'd give you enough room to draw new 4x4 blocks at the edges of it, then copy off a window from that.
This is not the most efficient screen refresh around. It's fairly typical for even the better Spectrum games to take 4 or 5 TV frames to refresh.
As for 'chasing the raster' with copying the screen, that's complete hogwash. It's just not fast enough. If you could copy the entire screen, 6K of data, in one TV frame then you could do it on the attributes too, and we'd all be using full-screen rainbow generators in every game.
I wonder why they wait before copying? (The code is dissassembled from the Maze game).
Also, you are right it is more like 2 x 79,000 (160,000) T-Cycles :-o
Right, time to be more realistic then :D
10-12.5 frames it is then :-)
However, I suppose if I did lots of POP's and PUSHES's and had a line for each of the 14 bytes...
The above takes about 250 T-Cycles
So we would have 144 Lines x 2 = 288 of the above
Thius would be 288 * 250 = 72000 to copy the 28 Columns by 144 lines (Interestingly 128 lines, or 16 rows) would take about 64000.
The trade off of course if that the above would be about 28bytes x 2 per row = 56 bytes * 144 = 8064 bytes for the code.
So you would need a backbuffer (6144 bytes)
The code to copy super fast (8064 bytes)
Doesn't leave much for a game :-)
So the trade off is to use the earlier code and aim for 10 - 12.5 frames per second
As the display is only 28*16 it's only redrawing about 58% of the screen each frame, which helps, and could be using a number of methods - you could certainly draw the whole thing to the back-buffer, and then blit in that time, or to the front buffer directly, or just scroll the old data in the required direction, and then fill-in the blanks from the new data. One speed-up to be had when drawing the whole thing is to make any tiles which have no graphic use the same paper & ink colours - as you then don't need to blit the graphic at all as it won't be seen.
(Coincidently I'm currently doing some scrolling code in a snake-type game - see the "New Game Ideas" forum)
https://twitter.com/bobsstuffgames
https://www.facebook.com/bobs.stuff
http://www.bobs-stuff.co.uk
Cool, so basically SPIN has confirmed that the Maze Mania games is updating at 12.5 frames per second.
I will check out the scrolling game you are working on too, thanks.
You can also poke bytes onto the screen - if they change the scenery, the changes will scroll along with the scenery. If you poke into an empty area of screen, they won't.
All the game sprites are then drawn from character blocks - a huge batch of UDGs - but are only copied to the screen where there isn't any scenery, so they never over-write the foreground or get trapped in the scroll.
Pretty clever all round, and highly optimised.
Because that's just being lazy. If the screen is going to be blocky attributes, you should at least be flashing OUT 254 to extend the blocky graphics into the top and bottom border.
This is misunderstanding. SURE, you can't copy 6k in one refresh but you can rewrite whole screen without flickering.
When you start chase raster the beam is ahead. You can fill about half of screen memory before beam reach the bottom of screen.
Then beam is going to build upper border (14500T) and the upper half of pixel area (224*12*8 = 21504 T) and you continue in filling bottom part of memory. You just have to reach bottom border before beam.
It gives you one complete frame (70000 T) + frame without upper and bottom border (cca 43000T) = 113000 T.
Rainbow generator is something completely different because you have to be REALLY synchronized with beam.
correct: whole screen is probably imposible, just about 5000 bytes
I was assuming it was impossible because you can't do it in a single frame, but that's flawed logic. The rainbow generator is limited because it has to copy each line at the same rate that the beam is drawing the lines.
I can see Woody is going to keep making claims but not put up anything concrete or useful to this case. And paging screen RAM in and out doesn't count as a refresh.
Edit: Can't find the thread where this came up ages ago atm. Will look again later.
Edit 2: http://www.worldofspectrum.org/forums/showpost.php?p=140386&postcount=166 :)
/me doesn't recall the effect being part of a game being one of the rules.
I shall post demos as my game progresses
Thanks again
Rob only asked for a demo. Which, if Woody still has it, is quite fun to look at. I recorded an anim .gif in ZXSpin with it a while ago now, too. We found it while probing more of the 48k machine's secrets, quite by accident as I recall. Was pretty astonishing to watch - hardware scrolling at 50fps :-)
But if someone is going to try and tease or wind people up with cryptic postings when someone's actually asking for help and advice, then you'll have to forgive me for exhibiting zero sympathy.
about people who have done much, more for the community than you ever have. You made your bed, now lie in it.
Clever as what he's achieved is, I still fail to see how anything he's put here has helped Rob even slightly. If it had, I wouldn't have been critical. But, I called him on his deliberate attempt at a wind-up of someone who's trying to achieve something (or, from then onwards, me).
Frankly I had a miserable experience trying to get some ideas for coding myself, so if some old guard teasing or setting upon anyone new is the best you think this 'community' has to offer then nighty-night indeed.
But somehow I suspect that if Woody actually gave a flying f**k about anything I put then he'd have said so, instead of continuing the wind-up.
I suggest you read posts #16 and #23 in this thread very carefully as you've obviously the missed the subtle subtext of "Rob's got the code" and Rob saying "thanks".
This thread? I wonder why that was?
As for 'that thread', I'm not the one who went through and deleted a load of comments from it. In fact, since that 'episode' no-one can any more. Although maybe that should count as a great contribution to the community too in some way...
Wrong. I supplied the code and source to Rob. Which, by the way, was unrelated to this "scrolling" trick. That was thrown in only as a potential point of interest for some, and nothing more than that.
Oh look, wrong again. You showed a little bit of interest and I spent my time searching this forum to try to locate a link to the description of how I'd found it works on the real hardware and supplied you with that very link. Excuse me for doing that. My bad. Won't happen again...
But do you really need anyone being grossly offended on your behalf and leaping to your defence with a personal attack on me? What is this, the letters page of the Daily Mail?
