XBox 360 prices to go up in Great Britain
2»
  • edited August 2009
    AndyC wrote: »
    er, why would anyone want a PS3 again?
    engineering MD5 collisions I think
    jdanddiet wrote: »
    i just bought another megadrive for 99p.
    Where from?
    1980-20.. wrote: »
    Where from?
    poundland
    lol, couldn't resist.
    i bought a n64 from a car boot for 3 quid. you can get loads of old systems dirt cheap, people just want shot of them. or a charidee shop.
    poundland
    Only sysyem i have ever seen in a charity shop was a nes but it wasnt exactly ditr cheap,think they wanted about 30 quid for it but it was boxed and looked almost mint. I defo need to get in on some car boot action though.
    Arjun wrote: »
    The new Arcade version and the Elite version are generally considered to be reliable since they use a different manufacturing process than the older models. With the Pro being phased out these 2 are your current choices anyway! IAC, don't let the failure rate hold you back - MS has a 3 year cover on the RROD - so a replacement (generally done within 3 days if not on the same day) is just a call away.
    The new "Jasper" motherboards use less current and run at a much lower temperature. As the main cause of RRoD is boards fracturing under prolonged heat stresses, this problem *should* be resolved.
    My Jasper Xbox 360 runs at a cool temperature, when you put your hand behind it, it's barely luke warm, unlike previous models where it can get very hot.
    Plus Jaspers run much quieter too. When you play games off the HD, the noise is barely noticeable, certainly not distracting. I've had mine since March and play on average 1-2 hours a day, and no problems (yet).
