I've killed my computer.
edited September 2009 in Chit chat
I killed my computer yesterday :(
Worst part about it deep down inside I knew what would happen but pushed the button anyways and now the thing is riddled with virusus and nasties.
I have one of these Zoostorm computers that you don't get a windows reinstall disc with, instead its hidden away in a partition you access from a reinstall menu when you turn the pooter on, however that too has been infected and dosent work.
To make thing worse I went and downloaded smitfraudfixtool, which aparently is also the wrong one and just does even more nastieness.
Programs were dropping left and right, I think I've saved most of the important stuff to a dvd... but I'll need to scan that as and when I get sorted :(
I think I'll have to buy a copy of Windows XP as I hate Vista with a passion... and I'm not speaking to McAfee Anti 2009 any more...
Pretty pants weekend in all.
Ho hum
Post edited by ZX Beccy on
  • edited September 2009
    Beccy if you have access to another PC download and burn this to CD (Which I assume you do 'cos you posted):
    http://download.bitdefender.com/rescue_cd/
    Then boot the screwed PC from it and run the scans.
    If you don't have a bootable CD on your PC there is a method to make a memory stick bootable with this system so long as your BIOS supports that kinda thing, but CD is easier.
    /Edit...
    If you have your screwed PC connected to the internet when it boots the CD will do an update to the latest AV database.
    /Edit
    /Edit2...
    Drive by download? Your computer is infected. Click here to fix the problem?
    Slap your wrists.
    /Edit
    /Edit3...
    If it's any consolation you're not the first and you won't be the last, and AVG allowed a client of mine to do exactly the above - and AVG wouldn't remove the rootkit that got installed :(
    Had to do the boot scan thing.
    /Edit3
    grab a copy f spybot, search and destroy whilst you're there
    Chuck some TCP on top of the computer, disinfected mine perfectly
    psj3809 wrote: »
    is that what you do with your (censored)
    :razz:
    ZX Beccy wrote: »
    Why 'buy' ? The PC should have a valid COA sticker on it, you just need someone to lend you a CD.
    And, do you know what it was thats got onto the PC? you may be able to clean it up without resorting to nuking
    General Malthadius Zoff
    Magenta icon
    Zoffy wrote: »
    unless the current windows license is not for XP...
    also the CD has to be the right type too, otherwise the key verification will fail.
    dekh wrote: »
    /Edit...
    /Edit
    /Edit2...
    Slap your wrists.
    /Edit
    /Edit3...
    /Edit3
    Cheers for that - will try
    Zoffy wrote: »
    Sadly hermits don't have friends with copies of vista... and I hate vista and want to go back to XP... and I have another computer thats going in a mame cab that needs an OS so it would be nice to actually have a windows disc... Oh, and I hate vista.
    Sadly I have no idea what go on it. All I know is each time I set the computer to an earlier backup everythings fine, then programs will start shutting down and be deleted from the computer... firefox, then IE, then whatever else I want to use!
    Gggrrr...
