My car is fooookked!
Went out driving today, and the high temp light/gauge came on....
Pulled over, checked the water. NONE IN THERE!!!
So, filled it up....went on my way...
Temp was normal and car seems normal....
When I got back, I checked the water again...and its gone :(
Where is it going....Any ideas??
Ive checked the oil, no muck in it...It has had a new head gasket years ago...
Think it does leak a bit on the road when it is parked up
Post edited by DATACORDER on
put some dye in it which you can buy from the auto store and then watch closely while you run the engine...check the exhaust too to see if that looks strange...i.e a lot of steam in it....probably a hole in the radiator, hose or leaking gasket...the dye will help a lot.
Park it up and have a look underneath to see where the waters coming from. That happened to me once, one of the jubilee clips had practically broken so water was slowly leaking out.
you've got a cracked radiator / leaking water pump / cracked hoses someplace.
possibly
Gonna take it to my local garage tomorrow
which is what I said, sort of. :)
If not, it may be the head-gasket that's blown.
And that's quite a bit of work (and money) to fix.
Not if he strains the white out through a colander.
And if it wasn?t it will be if the engine were run too hot/boiled.
could explain why your car conks out after one of 'em goes empty?
try purchasing some petroleum distilate from ye corner BP shoppe and shoving it in the hole near the rear
i did that once, got a slap for my trouble.
Still stunned all these years later when women (sorry for being sexist but from what i've seen its true) still cant change oil/add water.
it can't take you that long to buy tampons and make up.
It's the choosing that take the time, not the buying. (they do the car in 30 mins though)
thats what they say, they are prolly joyriding it round the car park.
