Xbox 360 hard drive
edited November 2009 in Chit chat
Hi all
Have just been asked via a very long chain of people if it is possible to recover/back up data from an Xbox 360 hard drive.
I assumed it's a case of putting it into a PC and reading the files from there but googling says different so am wondering if anyone has any knowledge of this?
At this stage I don't know what is wrong with the machine and am guessing that the HD is ok but of course it may not be.
Thanks
S
Post edited by Spex on
  • edited November 2009
    Spex wrote: »
    Hi all
    Thanks
    S
    don't you transfer the data to a new hard drive (on a new 360) via a special xbox cable? i didn't think you could pull the data onto a PC?
    Just found this... not sure if that helps at all.
    Thanks so far, I didn't mention that the Xbox "isn't working" but I don't know (yet) if the hard drive is the bit that "isn't working".
    Its one of those faults where the initial diagnosis report isn't very helpful!
    I was just assuming that as its a hard drive, it could be plugged into a PC and the files read but like mile said, special cable from Xbox to PC, which won't do it as xbox isn't working!
    Thanks again
    S
    Whats wrong with the Xbox?...RROD?...if it is that is real easy to fix.
    Spex wrote: »
    The 360 will work without a hard drive, so if it doesn't work with the hard drive detached the problem lies elsewhere.
    As far as the harddisk does, if you run the Xbox's repair disk option (which basically does chkdsk behind the scenes) it should fix it. If it doesn't, the hard disk is buggered and the stuff on there is basically lost. There is a special transfer cable that will move the data from one hard disk to another, but it kinda relies on both disks being functional already and, in any case, it's a complete transfer of data not a backup.
    GreenCard wrote: »
    That's for the orginal xbox and requires a modded dash, it won't apply to the 360.
    AndyC wrote: »
    Oops... sorry!! :oops:
    How about one of these? Sounds like it might be what you need.
