Virus Alert HELP
edited November 2009 in Chit chat
Dear Tech Support:
2009/11
I am still having trouble with this program. I was told that Blair v7.0 would continue being in operation until at least 2010. Yet I have discovered that since the Iraq update Blairv7.0 is no longer supported. Instead Laboursoft advised me to install Brown V0.5. This has proved totally unsatisfactory. Brown V0.5 runs very slowly,is erratic and is very expensive. The specs for the Prudence program are totally off. No way will this run on 1mb Ram! More like 8mb Ram. I'm very disappointed.
How can I go back to Blair v7. ?
Ash
___________________ __________________
REPLY: to Ash
Tech Support: N.Urd
Ash
Sorry, but Blair 7.0 was becoming very unpopular and corrupt so Laboursoft took the decision to discontinue it. You had Brown V0.1 already installed as a utilities background program with Blair V.1.01. It had some useful features like SellGold and the game BoomBust. However Brown V.05 is the operating system and is proving very difficult to remove. I will send you patch 1.00 Miliband to see if this helps.
REPLY:Ash
Installed Miliband patch but it did not do anything except add a banana logo to the opening screen. It totally failed to purge Brown from the operating system. Also I now find that Chancellor/resentful/bitter which was a separate program under Blair V.07 is now part of the Brown v.05 core program and cannot be operated independently. Its very frustrating as that is where the finance files are. Also Brown V.05 is taking up a lot of the resources from the other programs. Its constantly relaunching itself from the desktop. I don't believe this program is very stable.
I've removed the Vince data Cables as they weren't doing anything and tried booting from a previous 1997 backup but it won't restore. I just get this message
ERROR ?200,000,000,000,000 UNSUPPORTED DEBT.
DO YOU WANT TO REPORT THIS CODE TO THE IMF?
REPLY:Tech Support: Ash.URL
Hi Ash
On Livingstone V8.0 I used Bozone and it completely cleaned out the registry and restored all the corrupted files. Have you tried that?
REPLY: Ash
Bozone is only a London local program and cannot delete Brown V.05. I have just checked for Spyware.
WoW. I ran DavidDavis and found 1000's of spyware all over the place. Jacqui CCTV, JohnsonDNA, 42 daysReid, Eye-Dcard-4U. There is also a program called Mandlespin and Equality restore. What do you think. Is that bad?
REPLY:Tech Support: N.Ash
Yes that is bad. Mandelspin is a self replicating backdoor worm that pervades everything without any user intervention. It does not attach itself to any existing programs but still consumes huge resources and keeps spreading itself. Do not open anything up if near Mandelspin.
Equality restore looks harmless but it is the old Harmanx Trojan under another name. A very nasty piece of spyware and as hard to remove as Brown 0.5. Harmanx monitors your bin levels, methane emissions, alcohol consumption, double-entendres, skirt lengths and also all emails and phonecalls. Harmanx can also lose all your data and transfer your online accounts to a failed bank.
I'm afraid it may have to be a complete reformat. Even then that may not work and you might have to just junk the whole PC and start again. Election2010 is promising to remove Brown V.05 and all that other malaware completely but its not available until the new year Then you install Cameron V1.00 and hope for the best, but that's completely untested at the moment.
Post edited by ASH-II on
  • edited November 2009
    ASH-II wrote: »
    Cameron V1.00
    Don't you mean Tories 7? ;)
    I so hope you copied and pasted that 'joke' from somewhere else ! Very geeky joke !
    psj3809 wrote: »
    YES.....YES I DID (made me laugh so I thought I would share)
