128 +2 tape deck
I am not 100% sure what to buy to fix it.. first. scuba dive worked / loaded..
then games after didn't.. should I just got for the tape belt?!?! or for a new motor also? and as for the belt size, what size.. I see folks selling spectrum specific ones, but is that just because..
I was assuming I could use an external tape deck, I tried and nothing. I could hear sound and thats the lot.
the deck makes like a ticking noise as it turns / loads.. and it's like the pulses are speeding up / slowing down.. much like you used to get with them speedlock loaders years ago, where it sounded wobbly.
Post edited by fog on
http://www.worldofspectrum.org/forums/showthread.php?t=27190
see if I buy some belts for it, sods law it's the motor.hehe.. I dunno I gave a ?10 for it and got a good deal.. same with the rubber key 48k I bought that cost more.
only reason I got them was they were local pick up only ones.. what you mean a 70 mile round trip isn't local? :)
this is a black +2, not a grey one.. and it has the tape/game port on the side, although it doesn't input ?!?! I dunno .. I tried loading stuff. could hear sound, but nothing else.hhmm
I've ordered a tape belt and I have head cleaner stuff, so maybe that'll fix it.
funny thing is, I'm pretty sure I have a tape deck (normal one) at home doing the exact same thing..
I still couldn't get the input to work.. well assuming it's that. the tape input like on the +3 , top left corner.. it is also an input or just an output? I did look for the owner manual on here..
as for the line in thing on the +2. it's odd it produces sound, but no loading.
I would like to get the +2 manual to see what it says.
I'll have to do a bit more research into how it works I guess :)
I haven't messed with the azimuth.. I know what your on about though.. I'm well aware from c64 days about it :) the little screw inside the cover.. I think either the belt / motor or rollers is the issue, due to it speeding up / slowing down.. azimuth is the last thing I will mess with.
I also had the clicking sound - the pause button was not quite lifted and that was causing the clicking and stopping the reel turning on play properly. Having rectified that, it was more obvious the drive belt was at fault as although the tape appeared to play ok, when rewinding a tape, it would slow down a few times towards the end .
However, I have also had a look at another +2A and +2. The tape deck in the +2 is different to the one in the +2A and the drive belt also seems to be a different size on the +2 - put it on the +2A and the motor didn't manage to turn the reels at all.
Strange, but now I still need a cassette drive belt for a +2A
www.rwapsoftware.co.uk
www.sellmyretro.com
Polea cuadrada D =74 x G = 1,2 x A = 1,2mm.
