Help me fix my Colecovision!
I can't afford to shell out ?120.00 for a new one, so please help me. I've got the soldering iron out and the Maplins catalogue on standby. Here's the problem...
Whether there's a cart in the machine or not, the screen is the same on power up - just a crashed mess of static green squares, a few rogue pixels and an exclamation mark near the bottom. If I waggle the flex on the joypad, then the screen corrupts a bit more, sometimes with flashing squares. If I waggle the power cord, the same thing happens.
It sounds pretty terminal to me, but these things are blinking expensive!
HELP!
HELP!
Post edited by Graz on
Can you confirm that the title screen is there, even if madly corrupted?
EDIT: Yeah, checked and you should look at section 13.1
I hope this helps
http://gametz.com/user/platinumfungi.html
