Restoring yellowing computer cases
I have a pile of old hardware, load of Amiga's and one C64, and were wondering how to remove the yellowing from the casings of my vintage computers.
I stumbled across this:
http://retr0bright.wikispaces.com
It a recepe to mix up your own whitening formula. The ingredients are widely available and the page gives details how to make it and how to apply it to your old computer cases.
The creator's named it Retr0Bright... Has anybody tried mixing some up and applying it to their old cases? I just about to get my ingredients and make some of my own :)
Post edited by Hercules on
probably the same thing.. BUT maybe it has an effect on the casing making it brittle etc.. this is the issue with some of the plastics, as they were given extra treatments.. and that changes the chemistry of the plastic itself.
you only can do it so many times I guess.
...Indeed, but it's tried and tested with plenty of discussion on how the chemistry works on the plastic if you read on that page... I gonna conduct some experiments on some old bits of abs plastic first... You can mix the stuff up and keep it in a storage jar for safe keeping, but oxy action must be applied just before you use it. Maybe we can compare results on how our old computer cases come out afterwards.
the only thing that has gone near my older machines is washing up liquid..
Just remember, it's the patina that counts :grin:
This trick works with vinegar, coca cola, and lemonade, but I wouldn't want to dip my casings in any of those either :D
well coca cola / vinegar is well known.. vinegar for glass.. is used in glass cleaners errm cola.. well drop a tooth or some copper coins in , leave over night.. the coins are .. tooth vanishs (due to sugar) .. errm but i doubt either would have any REAL effect on the casings as they aren't errm harsh / ambrsive as proper cleaners / chemicals.
as for cillit bang.. it's over rated ... tried it.. it's not all it's cracked up to be.. and it'd never touch a puter I was cleaning.
and WTF is barry scott?!?!
only thing I know is someone did a mix of that n the esure advert.
It's called BAM! here in the US, and it was hawked by the late great "Billy Mays", who although annoying was way better than Barry Scott....who is a twat :D
