My Car Is..... Advice Needed!!
edited January 2010 in Chit chat
Well I am a nob head!!...(I know, I got that in one!)
Well, brought some anti-freeze yesterday, was gonna put some in the motor this morning/today....
Got up for work...wouldn't start :(
Bloody hoses/pipes were froze and also the water in the tank.....
I think I'm gonna have to get it towed and put it in the work's warehouse for a bit, and let it thaw out naturally.....
Any advice???
Am I doing the right thing???
I have only started tried to start the car once, and that was this morning :(
Heard about that you ice can break the "block" or water pump..... :(
Really hope it hasnt done that
Post edited by -RubberKeys- on
  • edited January 2010
    Stable door, horse, bolted.
    Does your car have a block-heater?
    If so, then plug it in! (Or is that just a US thing?)
    Wouldn't start in what way? Did the engine turn over and not fire up, or did nothing happen at all?
    Also, what exactly do you have and is it petrol or diesel?
    hypostomus wrote: »
    It wants to start but doesnt if u get my drift.....nearly fires up
    Petrol too
    spray some Easy Start down the air intake, don't make a habit of it though.
    On a more useful note....
    If you can get it inside do so. You can use a hair dryer to thaw out the pipes but that probably won't be enough to defrost the pump.
    If you can get it inside try and get one of those industrial airblowers on it. There will probably be one in the warehouse anyway to keep it warm so you might as well get the most from it.
    Even when its defrosted be careful because the expansion of the frozen water might have cracked joints / pipes or even the pump.
    Just had a look at the pipes...
    They are squidgy now, and if you press/squeeze them (esp. the one to the radiator)...you can hear a sound to tank...like its bubbling the water....
    But it looks like the water in the tank (min to max tank)...is solid....
    Do you guys think its best to try and start the car or will it damage something??
    Sorry for the crap description but aint got a clue about cars (hence me not putting any antifreeze in to late!)
    Oh yes, its still got a shit load of snow/ice etc..all over the damn thing...
    Best to give clean it all off or leave it on for insulation lol
    ADJB wrote: »
    Thanks mate, yeah gonna get it in warehouse...1st thing tomorrow morning and leave it there until Monday....
    Should thaw it out
    I really hope I aint f*cked the car up :(
    I don`t know anything about cars, but I would assume that the only safe way, is to allow it to naturally thaw, there is no point rushing anyway as in most places, the snow is too bad to use it anyway. If we get the next cold spell which they predict, it is perhaps better to keep it under cover and slowly coax it back to life....Good luck !
    thx1138 wrote: »
    They really do get addicted to Easy Start. I knew an ex citybus (one of those minibus things that's bigger than a Transit, but not as big as a normal single decker) that was so hopelessly addicted to Easy Start, the air intake was in the cab so you could squirt a bit in while cranking the engine. It wouldn't even hot start without some.
    I suspect the "addiction" is some additional wear to the rings so until the engine is up to speed, there's too much blow by and the compression isn't good enough for the diesel to light up, so the more you use Easy Start the harder it gets to start without it.
    Any advice???
    Firstly what do mean by "water in the tank"
    murtceps wrote: »
    Where you would put the water and antifreeze mate...MAX and MIN on the side...
    Im useless with cars...Aint got a clue...AND IT SHOWS :p
    If your water expansion tank is frozen its a good job it didn't start. The residue water in the block and head is without doubt frozen and it will blow your head gasket with overheating and probably crack your cylinder head. Very expensive. It does need to go inside somewhere and get that anti-freeze in double quick before you even attempt to start it again. I've done it myself, not had any anti-freeze in and come the winter I regretted it.
    The expansion tank then,
    As Dave say's if that is frozen you need to get it defrosted before you do anything.
    My english is bad so i could probably be missing something relevant in the discussion but:
    Antifreeze goes into the fueltank. It's not normally needed no matter how cold unless you have water in the fueltank.
    Into the radiator goes radiatorliquid, maybe mixed with a little water but not to much or it will freeze. If the liquid in the radiator and expansion tank is frozen there is a good chance something has broken.
    MinerWilly wrote: »
    I know that I don't know much about cars mate, but I'm er.......pretty sure antifreeze goes in with the water pal and not the fuel :???:
    Ok, i did a little googleing and appaerantly you call radiatorliquid antifreeze in english.
    What do call what you are putting in the fuel tank then if you have water in it?
    Hello there Minerwilly! in the UK we put in a mix of 50% water and 50% anti-freeze in the radiator and petrol in the petrol tank, we find it works best like that :) Petrol won't freeze... well not until it gets to -60 anyhow. However us English in general are a bit nuts, we put two eggs into a radiator to stop it leaking, it works for about ten minutes, enough to get you off a hard shoulder. Always carry eggs, if all else fails at least you get a poached meal.
    You mean in the UK you don?t use water to power your cars yet? This is old technology, invented in the eighties. KITT in Knight Rider was one of the first to do this! ;)
    Without going into too much detail I once had to make my own windscreen wiper fluid on the motorway.
    Actually MinerWilly is quite right ... here in the northern US, where it frequently gets down to -30?C in winter, people do put ... err ... some sort of antifreeze liquid in with the petrol. I don't have a car but I do remember when I used to drive that I had to do that occasionally.
    That same "fluid" is also very handy if the doorlocks has frozen!
    ZnorXman wrote: »
    Yeah, i had once a car where the fuelpipe had rusted so bad that water got in. Not even antifreeze where enough in the end.
    I have a 1999 Ford Focus with a 1.8 Zetec Petrol Engine, its been very reliable and never said no to starting in the cold. It had been sat in a car park at the end of Bristol Airport's runway for the last three weeks and turned over and started instantly in the early hours.
    I've never had a problem starting a Zetec Engine in the cold. My previous car had a Zetec 1.6 and that was the same.
    I did this nearly 20 years ago to a crappy old Metro and to thaw the pipes/engine I just kept refilling hot water bottles into the nooks and crannies and padding it with blankets. As soon as it felt thawed (like yours is now) I sat for half an hour revving the engine until the engine felt warm. I took it for a spin around the estate for an hour to make sure everything was defrosted and that car never had any ill effect.
    It's easily done if you don't drive every day. I now cycle to work but I've made sure I've started the car each morning and got some heat circulating. Never put any anti-freeze in this one.
    Vampyre wrote: »
    You don?t live close to me, that's for sure! This moring it was -29?C outside here. :p
    MinerWilly wrote: »
    Holy crap!!!
    The wife's car reckoned it was -6C at 7.30am and my bike thermometer said -4C in the shed at the same tiime. I reckon with the wind chill on the pushbike I was getting maybe -8 to 9 as it was blowing a gale this morning.... I had snotticles by the time I got to work!
    But -29C!!!!!! Do you even bother getting out of bed?!!
    I think the British Isles would internally combust if it had such temperatures (but only if London hit it). The 24 hr news would implode from such devastating temps, the reporters would need oxygen masks as it would no doubt be freezing the very air that they breathe.
    Everyone else in the UK would get the bloody hell on with it.
    I mean, how dare it snow in the middle of Winter!
    The coldest temp on record where I live was -51?C back in '96 ... and that's without the wind chill.
    MinerWilly wrote: »
    Well ... it was -35?C outside here this morning ... so there ... neener-neener ... I win! :-P ;-)
    If you and I were to have a pi$$ing contest we'd have pi$$icles ... not something to brag about really ( Nor something you should mention outloud! -Ed ) .
    ZnorXman wrote: »
    Let me ask this, does AdBlue really have pig wee-wee in it?
