My Car Is..... Advice Needed!!
Well I am a nob head!!...(I know, I got that in one!)
Well, brought some anti-freeze yesterday, was gonna put some in the motor this morning/today....
Got up for work...wouldn't start :(
Bloody hoses/pipes were froze and also the water in the tank.....
I think I'm gonna have to get it towed and put it in the work's warehouse for a bit, and let it thaw out naturally.....
Any advice???
Am I doing the right thing???
I have only started tried to start the car once, and that was this morning :(
Heard about that you ice can break the "block" or water pump..... :(
Really hope it hasnt done that
Any advice???
Post edited by -RubberKeys- on
Stable door, horse, bolted.
Does your car have a block-heater? If so, then plug it in! (Or is that just a US thing?)
Also, what exactly do you have and is it petrol or diesel?
It wants to start but doesnt if u get my drift.....nearly fires up
Petrol too
If you can get it inside do so. You can use a hair dryer to thaw out the pipes but that probably won't be enough to defrost the pump.
If you can get it inside try and get one of those industrial airblowers on it. There will probably be one in the warehouse anyway to keep it warm so you might as well get the most from it.
Even when its defrosted be careful because the expansion of the frozen water might have cracked joints / pipes or even the pump.
They are squidgy now, and if you press/squeeze them (esp. the one to the radiator)...you can hear a sound to tank...like its bubbling the water....
But it looks like the water in the tank (min to max tank)...is solid....
Do you guys think its best to try and start the car or will it damage something??
Sorry for the crap description but aint got a clue about cars (hence me not putting any antifreeze in to late!)
Oh yes, its still got a shit load of snow/ice etc..all over the damn thing...
Best to give clean it all off or leave it on for insulation lol
Thanks mate, yeah gonna get it in warehouse...1st thing tomorrow morning and leave it there until Monday....
Should thaw it out
I really hope I aint f*cked the car up :(
They really do get addicted to Easy Start. I knew an ex citybus (one of those minibus things that's bigger than a Transit, but not as big as a normal single decker) that was so hopelessly addicted to Easy Start, the air intake was in the cab so you could squirt a bit in while cranking the engine. It wouldn't even hot start without some.
I suspect the "addiction" is some additional wear to the rings so until the engine is up to speed, there's too much blow by and the compression isn't good enough for the diesel to light up, so the more you use Easy Start the harder it gets to start without it.
Firstly what do mean by "water in the tank"
Where you would put the water and antifreeze mate...MAX and MIN on the side...
Im useless with cars...Aint got a clue...AND IT SHOWS :p
The expansion tank then,
As Dave say's if that is frozen you need to get it defrosted before you do anything.
Antifreeze goes into the fueltank. It's not normally needed no matter how cold unless you have water in the fueltank.
Into the radiator goes radiatorliquid, maybe mixed with a little water but not to much or it will freeze. If the liquid in the radiator and expansion tank is frozen there is a good chance something has broken.
I know that I don't know much about cars mate, but I'm er.......pretty sure antifreeze goes in with the water pal and not the fuel :???:
What do call what you are putting in the fuel tank then if you have water in it?
Yeah, i had once a car where the fuelpipe had rusted so bad that water got in. Not even antifreeze where enough in the end.
I've never had a problem starting a Zetec Engine in the cold. My previous car had a Zetec 1.6 and that was the same.
It's easily done if you don't drive every day. I now cycle to work but I've made sure I've started the car each morning and got some heat circulating. Never put any anti-freeze in this one.
You don?t live close to me, that's for sure! This moring it was -29?C outside here. :p
Holy crap!!!
The wife's car reckoned it was -6C at 7.30am and my bike thermometer said -4C in the shed at the same tiime. I reckon with the wind chill on the pushbike I was getting maybe -8 to 9 as it was blowing a gale this morning.... I had snotticles by the time I got to work!
But -29C!!!!!! Do you even bother getting out of bed?!!
I think the British Isles would internally combust if it had such temperatures (but only if London hit it). The 24 hr news would implode from such devastating temps, the reporters would need oxygen masks as it would no doubt be freezing the very air that they breathe.
Everyone else in the UK would get the bloody hell on with it.
I mean, how dare it snow in the middle of Winter!
Well ... it was -35?C outside here this morning ... so there ... neener-neener ... I win! :-P ;-)
If you and I were to have a pi$$ing contest we'd have pi$$icles ... not something to brag about really ( Nor something you should mention outloud! -Ed ) .
Let me ask this, does AdBlue really have pig wee-wee in it?
