Immunity for Jackson City and Side Arms request
http://www.worldofspectrum.org/infoseekid.cgi?id=0002571
http://www.worldofspectrum.org/infoseekid.cgi?id=0009416
Someone could tell me the pokes to get immunity for these games?
Thanks
Thanks
Post edited by arkos on
If you scroll down the page on both of the infoseek entries you should see a tipshop icon:
This will take you to the tipshop pages which have pokes listed for both games
The problem is there is no immunity to poke Jackson City.
For Side arms, poke it seems that the immunity does not work with all enemies.
I thought someone would get the pokes.
utility recognizes the difference and gives you exact address.
some may know it too... Pavero for sure (my guess)
EDIT
this is it: HokeyPokey
http://www.worldofspectrum.org/utilities.html#other
Thanks for the poke, g00db0y!!!
One question, is difficult to find this kind of pokes?
Use HokeyPokey .... and try for yourself ;)
(and don't be shy to try more fancy utils made just to your liking, there's a lot of them)
I search pokes for new games only :-P.
http://www.zx-spectrum.cz
I stand corrected ;)
