48k spectrum restarts by itself
First of all hello from a newb and thank you for your help. This site has already offered me a lot of insight.
I have a 48k spectrum that will boot to the 1982 sinclair screen and will stay working for random times say 10secs to 20-30 mins and then it will restart as if I have pressed NEW - enter. Sometimes only once and often multiple re-starts and a crash.
I This page diagnoses the problem as "Check the TR6". Now on loking at it and http://www.worldofspectrum.org/SpectrumRepairGuide/ here I believe the voltages maybe wrong. But I am not sure, I have also looked here http://www.kpsec.freeuk.com/components/tran.htm and here ftp://ftp.worldofspectrum.org/pub/sinclair/technical-docs/ZXSpectrumIssue3b-Schematics.gif and would like to know if the BE BC and CE tests should be made with the spectrum powered down - unplugged. and indeed if any one can let me know which leg is which looking down from the top with the power facing away that would be great.
I am a humble hobbyist and have OK soldering skills but electrical diagnosis is not good although I can just about weild a multimeter.
So as well as re-setting, the system also sometimes beeps and re-sets and also occasionally the screen fills with ???? marks and crashes. I am thinking these other problems are symtoms of the TR6 resetting the machine and once its fixed the other issues will stop?
I have ordered new 2N2369 to replace the ZTX313 (TR6) however while I wait for these parts to arrive is there anything else I should be checking?
Looking at the description of how to test the 4164s I dont really understand where the -ve multimeter lead should go when looking at the voltages at various legs. However because my system starts I was able to do teh POKE - PEEK command to check the memory and it all seemed correct.
Finally - sorry for such a long first post - I ahve removed ands re-seated my ULA a couple of times. It is the only chip that is not soldered on my3B board. I have also change the UHF output to be composite video following the excellent guide here http://womblesretrorepairshack.blogspot.com/2008/11/zx-spectrum-composite-video-mod.html.
Thanks for looking
Paul
Thanks for looking
Paul
Post edited by hedge on
Won't be long before they reply, :)
Damn, nearly forgot... WELCOME TO THE BEST FORUM ON THE NET, :D
You can check if spectrum detect all ram. Write
PRINT PEEK 23732 + PEEK 23733 * 256
The value printed should be 65535
bye
Jos? Leandro
The most common fault for otherwise-working-perfectly but randomly-restarting speecys it was 90% of the time due to the power cable having been pulled out and pushed in so many times a fault develops either within the power plug itself or the solder connections on the socket on the board. Ist things first try replacing the plug and/or resoldering the socket to the board. Very quickly removing and applying power will also cause the other crashes you were referring to.
Rgds
Could that plug still be a source for failure even under those conditions - excuse the naiveness just not used to electronics fault finding?
Lets see if this solves it.
to be continued.
Note when initial testing was done it was without a keyboard attached, just booted up to home screen:
- Replaced TR6 system worked for approx 45 mins before first re-start
- Replaced TR4 system restarted within a couple of mins
- Removed power port, re-tinned all the legs cleaned off all old solder and re-soldered making sure I had a good wet joint. System re-started after about 20-30 mins
- Removed the - 7805 regulator (I think) - 3 pin component that is attached to the heatsink. Re-tinned its legs and cleaned all the old solder off the board then cleaned the area that contacts the heatsink and indeed the area around the board. Re-soldered making sure good wet solder joints.
The machine has now run for many hours with no re-starts. Thank you for the help pointing me at the power area.
Paul
I replaced the faulty parts, and it failed again after 2 weeks.
Turned out to be faulty solder joints on a small heatsink that also worked as a connection for grounding.
I hate such faults. They're very hard to solve.
