Redefinable joystick keys
Er... difficult to describe in a subject line, but you'll see what I mean. :)
Just about all Spectrum emulators allow you to map one of the joystick formats to the keyboard, so you can use the cursor keys as your Kempston joystick, for instance.
What they don't seem to do (and other emulators do - C64 emulator 'Vice' and Atari ST emualtor 'Steem' do this, for example) is let you redefine which keys the joystick is mapped to.
Now I dunno about you lot, but I hate the PC cursor keys - I want to use Q, A, O, P and M. Someone feel like implementing this functionality into their emulator? It'd be a godsend for games that don't already have a redefinable keyboard option.
Post edited by Lee Tonks on
I've been trying to do something like this with your emulator but I can't quite figure out how to do it...
I managed to map one Speccy key to another, but I can't seem to figure out how to map a joystick direction onto a key. Any tips? :)
So... it looks like there's still no emulator which does what I originally talked about. Snap to it, emulator chaps! ;)
What Vladimir and Dr Beep are talking about is setting up your joystick to press any keys you like.
I don't have a joystick - I'm talking about EMULATED joysticks.... Kempston, Cursor, Sinclair... yes?
Take 'Spectaculator', for example. On the 'keyboard' tab of the 'options' screen, there's an option at the bottom which says 'Choose a joystick to emulate using your computer's arrow keys...', and it then allows you to select one of the Speccy standards. That's the functionality I was talking about - it's okay as it is, but I want to map the Kempston onto a set of user-definable keys and not onto the PC's cursor pad.
Is that any clearer? It's a bit difficult to explain. :)
Vladimir - your example is easy and works, but it maps key to key, not 'kempston direction' to key. Yes?
