Question
I've noticed on my living room, bedroom and kitchen walls small, hairline cracks on the plaster (and some in the stonework).
They seem to have appeared sometime in the last few weeks but i only noticed them last night. Does this mean that my flat is going to fall down? Could it be a problem with the foundations? Or is it just the building settling? The building is very old, was built around the 1890's.
Any comments from structural engineers would be welcome!
Post edited by zx1 on
prolly just getting old, cold weather might have had something to do with it.
Yeah just like this.
I've got a guy coming to look at a dampness problem in the hall next friday. I'll show him and see what he says.
We've got a few in our house (its an old one) but again its nothing to worry about.
I really would noy worry unless they are growing visibly bigger by the day or week.
When we have cold winters plaster tends to crack more often, because the difference between the hot and cold temperatures cause it to expand and contract more than usual.
During the snow of a couple of weeks ago the celing in my backbedroom / office developed a small crack all the way along the coving. This happened because the house was cold for weeks, then we came back from the USA and turned the heating up high. When we did turn the heating on we could hear the whole house going rrick tiick, tick. This I beleive was due to the process of expansion and contraction.
This isn't a terrible thing, probably just due to the fluctuations in humidity/temperature.
But this might be a cause for concern, especially after 120 years.
ZnorXman,
Currently Not An Engineer.
I can also get hold for a load of woodchip or anaglypta wallpaper. Dead cheap like.
What no flock paper, like in the Indian resturants ?
I can paint flocks on it for you - but that would be an extra ?25, tops.
EDIT - I've got a shed load of 'Action Man' wallpaper you can have cheap, ?40, but you'll have to take the lot. It doesn't look too bad if you have dim lighting in the room. Great for kids!
..unless they start to resemble faces like that bit in Silent Hill 4...
:eek:
Cracks in the plaster of new houses is very common, it's caused i think by the foundations settling.
It's the cracks in the stonework that are a concern, even though they are only hairline and you can only really see them when you are close up to them, is worrying. I might as a neighbour to see if they're having any problems.
