Faked MP3/memory sticks etc
2»
  • edited February 2010
    murtceps wrote: »
    Good luck, that's if you even receive it... That seller sells counterfeit flash drives, so just make sure you test it when it arrives. Info on that seller is filed in the sosfake flash database:
    http://sosfakeflash.wordpress.com/2009/02/08/best-e-bay-sell-ebay-fake-flash-seller-alert-devious-china/
    murtceps wrote: »
    Either way check out the "Free Gift:Wool Case Bag" I think that sold it for me.
    Looks like a smelly sock from some poor middle eastern worker. Hang it in the car for the ultimate air freshner accessory. Bargain !
    murtceps wrote: »
    I sniped this for ?8.50 inc P&P.
    It will either be a bargain or absolute crock (I suspect the latter).
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140378290794&ru=http://shop.ebay.co.uk:80/%3F_from%3DR40%26_trksid%3Dp3907.m38.l1313%26_nkw%3D140378290794%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1#ht_5393wt_907
    Well it's arrived.
    A quick review:-
    What's in the (Jiffy) bag:-
    USB Player
    Charger
    Earphones
    Instruction Book. In the worst English ever.
    Stylus.
    Sock (Not Smelly!)
    First was to check it with H2Testw 1.4, And after about an hour (!) it comfirmed it was indeed a 2GB chip installed, so no problem there.
    The touch screen is a little unresponsive, and there is no where to keep the stylus.
    It also has a SD card Slot, that turns out to be a mini SD so I can't test that.
    MP3 playback and the ear phones aren't bad.
    So as long as it lasts a couple of holidays it seems ok for ?8.50
    murtceps wrote: »
    Well it's arrived.
    A quick review:-
    USB Player
    Charger
    Earphones
    Stylus.
    Sock (Not Smelly!)
    Does it really do flash?
    Get yourself a Sansa Clip
    General Malthadius Zoff
    Magenta icon
    Zoffy wrote: »
    Yup that's what I've got, the headphones alone have outlived all the headphones I went through with my old MP3 player put together, infact the headphones may have even outlived my old MP3 player altogether.
    It's perfect for work I just clip it to my shirt and run the phones under it, good stuff, and I think it was only $15?
    Zoffy wrote: »
    Already got one.
    Nice but mine is only 2gb and they doesn't have the video option.
    Still waiting on my replacement '16gb' china one....
  • edited March 2010
    Update.
    Well the replacement arrived Friday from China.....you guessed it, it was another 2gb one faked to 16gb.
    I complained again, they refunded me...so I got 2 decent 2gb MP3 players for free!
  • edited March 2010
    Mine still hasnt come yet, give them a few more days and then i'll moan.
  • edited March 2010
    beanz wrote: »
    Update.
    Hmm, just make sure you don't put more than 2gb of songs on their, or you'll data wrap around and corrupted files...
    Incidently it is possible to re-correct faked flash memory to it's correct capacity. This first step is to correctly identify the VID and PID numbers of the flash memory / device then tracking down a program to reflash the firmware so it gives it true "real" capacity. SOSFakeFlash website tell you how to do this if you have a rummage on their website. Not sure if it will work on mp3 players, but well worth further investigation...
  • edited March 2010
    Hercules wrote: »
    Yeah I've already loaded them both up to 1.7gb and they are working fine at that.
    I was wondering if there was something to 'fix' the reported size, I'll look into that thanks.
  • edited March 2010
    Well I managed to 'fix' one of them last night following Hercules info that it could be done. Now it reports correctly 2gb and the test says everything is ok. Guess I'll do the other one tonight.
    So thanks for the info Hercules.
  • edited March 2010
    Well 6 weeks later and still nothing so i've emailed the guy and hes going to give me my money back (different paypal address hes using but i presume its all legit).
    At least hes going to refund me, the postage was a fair bit (15 quid i think) so i cant believe it takes that long to get here !
    Oh well
