Takes a licking but keeps on ticking.
So pcs are notoriously a pain in the arse and suposedly very sensitive pieces of kit, but what abuse have you seen a pc take and still keep running.
A few months ago at work two of my co workers managed to empty a cup of water into the pc we use every day the display went all matrix on em and sterted displaying random data. So the power was quickly turned of the tower was tilted to let the water run out a fan was placed next to the vents and an hour later it was up and running and is going strong to this day!.
Post edited by 1980-20.. on
I stripped it down and left it to dry overnight.
I've not fitted the keyboard back to the machine (the joy's of USB) but so far everything seems OK.
Well, good enough to boot the machine and take a disk backup!
I've not got a 486 any more, but I have a pentium 133 around and it's the same: you can pull out ISA cards without it noticing, it doesn't mind you hot plugging IDE hard drives either :p
I wouldn't suggest trying that on your shiny new dual core machines :)
(actually modern machines have sata drives, and you can hotplug those so we're going backwards ;))
I have a PC in my workshop that was originally my first desktop PC. Then it became my server and it was retired from that task because of random crashes and boot failures/hard disk errors.
I reckon the smoothing capacitors on the motherboard are dead, cause I fixed it by wiring a 2000 micro farad capacitor across the 5 volt line :D
Getting them to tell you the truth is harder.
S
mine had a cd exploded inside which killed the hard drive and bluray drive
fitted a new dvd drive and hard drive and it works fine now
if you get sugary drink (I've spilt tea into my keyboard countless times, but since I don't take sugar, it didn't seem to care :p) into your keyboard/laptop you do need to wash it out immediately. the easiest way to do this is to take the plastic case off and drop the whole thing in the bath. (unplug it and remove all batteries + hard disk first...)
for best results, once it is clean, rinse that water away with distilled water and let it dry naturally in air
course the best thing would be to just not spill your drink, or to have a full size keyboard that is by design spillproof.
beebs are pretty damn bombproof. The one thing you have to watch out for is corrosion on the keyboard ribbon headers. once the connection to the keyboard starts to go iffy you get all sorts of weird glitches.
the other main failure is the paper mains filter capacitor burning up in a cloud of acrid smoke.
